Radiator cracked, replaced it with an aluminum radiator, now tranny slips.
Old May 15, 2009 | 09:36 AM
  #41
ImmaSquashYou's Avatar
Ok, i just want to make sure that you know the difference between tranny slipping and tranny shifting hard. Being said, lets go to tranny slipping. If the tranny is slipping, its slipping. A frequent transmission oil change is only preventative maintenance to prolong the transmission.
Here is what i'm doing this weekend since i felt a little of a harder shift at halfway throttle on 1st to second. I'm going to be buying around 15 quarts of reg tranny fluid that are in the big 5 qt bottle (so i need 3 bottles), and then buying 5 quarts of valvoline maxlife, a tranny filter which comes with the gasket. I am going to drain and the fluid, replace the filter, drive around for 20 minutes and jack up the car again. I'm going to drain the fluid again, refill using the 2nd batch of 5 quarts, drive around for 20 mintues..come back. Drain the fluid, drive around fro 20 minutes, use up the last 5 quarts. Drive around a 10 minute again, drain the fluid, and the refill the tranny with the valvoline maxlife. Reason why i do this with 15 quarts is that if i'm not mistaken, there is about 10 quarts of tranny fluid in the tc? i forgot exactly how much, but this ensures that you have almost all new fluid in your transmission. If you want to make sure that you have almost all new (you'll never have all new unless you drain the tc by removing it or doing the flush) do it more times. is it a pita?? yes...is it necessary? you're the one to decide.
Again, if your tranny is on its way out, there is nothing really you can do. But sorry to yell, AT LEAST DRAIN AND REFILL YOUR FLUID AT LEAST ONCE!!!!!!!!
Old May 15, 2009 | 10:48 AM
  #42
williamgd2's Avatar
I had the problem LOR1DA is talking about.After 30 minutes of driving I would loose overdrive.Brand new radiator.I again replaced the radiator with a more expensive one and the tranny is fine.So it could happen to just be lack of good transmission cooling from your new radiator.But you should do something about your nasty fluid.
Old May 15, 2009 | 11:02 PM
  #43
mantis40's Avatar
Well the radiator i got in now is an all aluminum high quality radiator. There were no warning about not having tranny cooling lines and it says its for automatic. The transmission actually started slipping when I noticed that my first radiator was cracked. The fluid is definatly burnt and brown. It was about a half quart low so I filled it and it still slips. I guess I have to drain and fill. Hope it works.
Old May 16, 2009 | 12:21 PM
  #44
vqmaxman's Avatar
The drain and refill will be a good idea, If the fluid was dark red or dark burgandy but If the tranny is slipping than that will have to be corrected by pulling the tranny apart.
Old May 20, 2009 | 12:15 PM
  #45
maxed_out_99's Avatar
dark brownish ok black BAD
So one day I popped the hood with the car still running because I saw smoke, and I noticed antifreeze spilling out the top of the radiator. My resovoir tank was almost up the the MIN line so I started driving home. So I ordered a 100% aluminum radiator, new radiator hoses, and a new thermostat. I installed everything, and the car ran nicely and stayed nice and cool. Then I started noticing my tranny was slipping from 2nd to 3rd and even worse from 3rd to 4th.
Is my tranny always gonna be like this and eventually get worse? I checked the tranny fluid and it was pretty dark. Will changing my tranny fluid fix this? Anything I could do? I cant afford a transmission and labor right now.
Also I have a CEL code for my EGR valve, would that effect anything?
first you should smell the fluid if its black and smells like poo poo dont change it if its a little brownish your on the edge feel the fluid if it feels like sand or crap (not that i would know what crp feels like or anything) dont change it if its a little brownish and smells ehh your alright but it should still have a red tint
Old May 21, 2009 | 10:30 PM
  #46
DAVE Sz's Avatar
Hooooooonda.....
Originally Posted by vqmaxman
It is really risky at this point, because you don't know If the car has been serviced on or not, so try to get
that are sticking to the tranny are going to get flused out and the fluid will be new and slick nothing for the tranny to grip on.
holy horse crap! That is such BS that it's not even funny. Don't believe everything you read in the 4th gen forum. You'll live longer.
A trans fluid and filter(screen) change is never harmful...
CRizz
41
Jun 7, 2021 05:42 AM
Matt93SE
May 24, 2019 02:58 PM
seesole
Aug 26, 2015 11:22 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MikesChevelle
Aug 6, 2015 11:36 AM
