Throttle body gasket leak ?
Old May 18, 2009 | 02:57 PM
mahanddeem's Avatar
Hi
Can TB gasket leak ?
I cleaned my TB by removing it off the car...reintalled with new gasket(not OEM nissan ... the new one seems little thinner) ...now car at idle is ok (no air leak to hear) but when revving the engine to say 1500+ I hear hissing sound ! ....May be the new (not very good) gasket ?
How can I test it ? i'm sure all my TB work was as good as must be ...
Old May 18, 2009 | 03:35 PM
MOHFpro90's Avatar
Way to test it; get some carb/TB cleaner, start the car, and then spray it in the crack where the gasket is. If its leaking the idle will bounce up some.
Yes, they can leak. Are they as prone to leak as say, the manifold gasket or MAF seal? no.
Old May 18, 2009 | 09:32 PM
mahanddeem's Avatar
how can i check the downside of the gasket by this method ?
Old May 18, 2009 | 09:38 PM
MOHFpro90's Avatar
Just spray it up under there as best you can.
You could also try using a propane torch. Turn it on and dont light it, and if there is a leak, the propane will get sucked in and raise the idle. Its safer than it sounds, but its really a last resort.
Old May 19, 2009 | 01:11 AM
tosheto's Avatar
If you tied the 4 bolts evenly you should not have a problem. I clean my TB and put auto zone gasket on there and never had a problem.
Old May 19, 2009 | 06:24 AM
wxm's Avatar
wxm
x2 on bolt torque.
The FSM calls for torque all 4 bolts to 7 lb-ft, then 15 lb-ft. It is important that the bolts are tightened evenly.
Old May 19, 2009 | 02:16 PM
mahanddeem's Avatar
Originally Posted by wxm
x2 on bolt torque.
I tightned all 4 bolts to hell
Old May 20, 2009 | 03:09 AM
wxm's Avatar
wxm
15 ft-lb is not a lot. Hopefully you did not over tighten them either. Again, the key is to torque them EVENLY.
Old May 20, 2009 | 04:46 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
Evenly is the key word! But if you are still having problems you can first get another gasket, or I have seen where some members have used a very light coat of RTV to help seal the deal.
Old May 20, 2009 | 07:23 AM
mahanddeem's Avatar
Will a TB gasket leak turn on CEL or make a hidden code ? as a bank runs lean or something ? like EGR leaks............
Old May 20, 2009 | 09:29 AM
pmohr's Avatar
No more Maximas...
A CEL, possibly. It may or may not set a code, it's more a luck of the draw type of thing.
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
