ECU Help
Old May 25, 2009 | 09:24 AM
Steve31's Avatar
ECU Help
My car has been hesitating for awhile now so I went to chk for any codes
Turned the screw clock wise then turned on the key and nothing
Tried a diff ecu still nothing
Holding 35 PSI fuel press in park
95 SE Stock
Old May 25, 2009 | 09:44 AM
WhiteMaxima9600's Avatar
Are u wanting to check for codes? If so u need to turn the key on first then turn the screw clockwise wait a couple sec. then turn all the way back counter where it was first. Then your engine light will flash any stored codes.
Old May 25, 2009 | 09:56 AM
Product_Of_Korea's Avatar
my bet it will be
0304................. along with something else
Old May 25, 2009 | 10:37 AM
pmohr's Avatar
No more Maximas...
95 SE Stock
Is the CEL even on?
You aren't performing the check procedure correctly.
If you follow the instructions properly, it'll work. Simple as that.
If that's too much for you, just go to Advance/Autozone/etc and have the codes pulled.
Old May 25, 2009 | 11:03 AM
maxgtr2000's Avatar
KH3 by popular demand
A dead coil pack or bad spark plugs doesn't throw a code, have you checked them?
Old May 25, 2009 | 12:22 PM
Steve31's Avatar
I have pulled codes outa my 87 pathfinder before
But with the key on everything normal there should be a green led on in the lil peep hole on the ecu right?
Old May 25, 2009 | 01:16 PM
pmohr's Avatar
No more Maximas...
...no. This is not a VG ECU.
Have you even read the proper procedure to check codes? Sounds like you're just doing things randomly.
It's in the stickies: http://forums.maxima.org/4th-generat...first-cel.html
From your 00VI thread (http://forums.maxima.org/all-motor/5...00vi-swap.html) and this thread, I gather two things:
  1. You absolutely refuse to use the search function before asking a question.
  2. You absolutely refuse to read the stickies before asking a question.
If you can fix those two problems, you won't need to make new threads like these.
Old May 25, 2009 | 01:54 PM
Steve31's Avatar
I was just lookin for info on the swap
Did not know about changing the link to pull up old topics (thanks for that)
On this I found the problem
The chk engine light bulb was blown lol
Came up with these codes after fixing that
03-04 knock sensor
04-07 Crank Position sensor (reference) -----Not sure what this means
10-05 EGR Solenoid Valve
Sigh* Looks like spending more money lol
Old May 25, 2009 | 01:57 PM
Steve31's Avatar
Thought the 95 was also OBD-2 complient ?
Old May 25, 2009 | 01:58 PM
Steve31's Avatar
Originally Posted by locknuts
my bet it will be
Old May 25, 2009 | 01:59 PM
pmohr's Avatar
No more Maximas...
It is. No one said it wasn't
Old May 25, 2009 | 02:01 PM
Steve31's Avatar
I tried using a reader but it was like there was no power at the plug
Old May 25, 2009 | 02:02 PM
pmohr's Avatar
No more Maximas...
Did it say there was no power at the DLC? Have you checked for power at the DLC? Have you checked any fuses?
Old May 25, 2009 | 02:24 PM
Steve31's Avatar
I pluged up my scanner and it did not power on
All fuses are good cep the airbag its no big deal now I got what I wanted lol
I guess all 3 of those codes would result in some kinda power loose ?
Old May 25, 2009 | 02:39 PM
pmohr's Avatar
No more Maximas...
No, codes aren't going to affect power delivery to the DLC.
Check for power at the connector, see if it was just your scanner.
Old May 25, 2009 | 02:51 PM
Steve31's Avatar
No all the bad sensors would cause the engine to loose a bit of power right?
The scanner works I chk it on my wifes malibu
I got the codes now thats all I realy wanted realy don't bother me about the connector not working
Old May 25, 2009 | 03:12 PM
pmohr's Avatar
No more Maximas...
The CKPS REF could cause a loss of power, hesitant or no start, etc.
The KS can cause some issues in and of itself, but I wouldn't worry about that code until everything else is fixed.
The EGR SV won't cause a power loss unless it's sticking the EGR open at all times.
Old May 25, 2009 | 03:17 PM
Steve31's Avatar
It is hard to start at times
And getting worse
Also it is like when the rpm's get around 2800-3000 then it picks up like you hit it with a bit of nos or somthing
the EGR Soloniod is that the part on the intake just behind the TB ?
This part
http://cgi.ebay.com/ebaymotors/96-97...lenotsupported
Old May 25, 2009 | 05:06 PM
Yeah thats the bad knock sensor.
But like pmohr said i would do the ckps first. That will cause you to miss and have a rough start up. Id first start off by just inspecting the ckps. It could be as simple as its just covered in oil or has metal shavings on it.
For the ks there is a bypass that can be used until you can afford a sensor but you will have to Search for the answer to that one.
Old May 25, 2009 | 05:17 PM
Steve31's Avatar
Like this
470k ohm resistor
you must disconnect the KS sub-harness and install the resistor in the main harness upstream. If you examine the end of the sub-harness at the KS end, you will notice that there is only one terminal, despite two locations.
Old May 25, 2009 | 05:22 PM
Steve31's Avatar
I prolly just need to clean it off then I noticed the other day my front seal is seeping a bit
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
