can I use a 1996 ecm with my 1999?
Old Jul 8, 2009 | 05:07 PM
  #41
Maximeltman's Avatar
Can ecu's just die on their own after a while?
Is a possible reasoning for a short in the ecu a faulty IACV? I read it in the Hynes manual that it should have around 30 ohms resistance between all the pairs of the pins, IE:
Checking between pins 1&2=30 ohms, 2&3=30ohms, 3&4=30 ohms, 4&5=30 ohms, and 5&6=30 ohms.
I measured 30 ohms on all pairs, except at pair 3&4, where you need to measure diagonally...there I read overload or infinite resistance. Can anyone test theirs and see?
here is a crappy diagram of it, and the two lower case L's are there to represent the fastening clip..
l l
123
456
Old Jul 8, 2009 | 05:42 PM
  #42
Product_Of_Korea's Avatar
I was just using my iacv as a example. I wasnt aiming towards your iacv may have been faulty or what ever. My case was human error on my behalf. By all means i was not relating it to your situation
Old Jul 8, 2009 | 06:12 PM
  #43
I know, but I did a serach for what causes ECU failure, and someone had theirs short because of a faulty IACV
Old Jul 9, 2009 | 10:30 AM
  #44
bump...anyone test their IACV for resistances please?
Old Jul 9, 2009 | 11:08 AM
  #45
pmohr's Avatar
No more Maximas...
Sure it wasn't an A33? Those are failure prone to frying ECUs, but their IACV also has coolant running through it, which damages the stepper motor.
You mean beyond all of the specs listed in the FSM?
You're not supposed to check between 3 and 4:
Old Jul 9, 2009 | 01:20 PM
  #46
Thanks, but duuuudde....my Haynes told me to check all pairs in consecutive order...
I'll do what this one says also then. I just want to find out what the hell may have caused it to fry. I have another REF on the way so I'll try that first then go from there.
BTW, could I just plug the ECU in the harness without actually having to stuff it back into the bracket under the center console, or does it rely on the bracket to ground it?
Old Jul 9, 2009 | 02:05 PM
  #47
pmohr's Avatar
No more Maximas...
Bracket is useless (as far as I've seen), you can run it without putting the ECU all back in there.
Old Jul 9, 2009 | 02:45 PM
  #48
Originally Posted by pmohr
Sure it wasn't an A33? Those are failure prone to frying ECUs.
So maybe it wasnt my fault that it fried my ECU x2. I know that one of the pins was bent a little bit but im sure it still went into my 4th gen harness. And i did have the coolant logs hooked up as well. hmmmmmmm intresting.
Anyways...... To me its kind of weird that you are throwing a code for both CKPS's I would almost suspect the ground that hooks up to your lower manifold are in bad shape. But on the flipside it still wouldnt explain the other weird code that you have. But if you had somekind of smoke inside your cabin that would make me suspect that something is shorting out.
Have you recently done any kind of wiring or modification to anything???
Old Jul 9, 2009 | 10:30 PM
  #49
no wiring mod...only thing I did about 2 months ago, and the last thing I did, was put the phenolic spacers on..Now I wonder if I might have broken a wire on the engine harness because I had to bend it out of the way?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Excalibur23
Oct 13, 2015 04:33 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
