My A/T is hitting very high RPM, is this limp mode?
Old Jul 9, 2009 | 07:36 AM
Xservice0183's Avatar
The only Pre-existing issues with my car are Sticking Rear Calipers.
This morning as I drived into work today, I noticed a heck of a lot of power on the butt dyno. The Tachometer was always a 4000+ while on the highway, at just 60mph. It would keep going as much as I accelerated too, apparently not switching gears. I also tried O/D off and did not notice the usual gear change.
I don't have a Check Engine Light. I know I can't continue driving this way. I don't have a spare ECU. I haven't tried anything, because I'm at work, but What is the likely culprit?
I understand the car is not shifting into the smaller gears. What are some things I can try before swapping a rebuild tranny?
Old Jul 9, 2009 | 07:39 AM
asand1's Avatar
Firts things first, check your fluid. full? burnt?
Old Jul 9, 2009 | 07:55 AM
96 5SPD SE's Avatar
could a shift selenoid maybe
Old Jul 9, 2009 | 07:58 AM
Ah ****, the fluid was fine, but I tried the gears and it wouldn't shift from 1st to 2nd, only Reverse to 1st. =(
Old Jul 9, 2009 | 08:10 AM
allensteiner21's Avatar
might be the tranny control unit.
Old Jul 9, 2009 | 08:51 AM
When I change the gears from 1st to 2nd I don't feel anything.. 1st to Reverse I do feel it. Can the TCM be the culprit?
I did change the TCM within the last 5Kmi, and I have the old one handy.
Old Jul 9, 2009 | 09:18 AM
pmohr's Avatar
No more Maximas...
What do you mean when you change from 1st to 2nd? Do you have the shift_fast mod or anything done?
If you mean when you move the shift lever from manual low up to the manual 2nd position, you're not inducing a shift by any means. You're just letting the TCM shift when it wants to.
For starters, why did you swap out the TCM in the first place?
Did you do anything to the car before this happened? Did anything happen to it?
Have you tried removing the negative battery cable just for kicks, to see if it changes anything?
You said 4k @ 60 MPH, that's 3rd gear. When does it upshift from 1st to 2nd, and 2nd to 3rd?
Your CEL does work, correct? You're sure the bulb isn't blown out?
Old Jul 9, 2009 | 10:17 AM
No mods. Ok, point taken.
The CEL was indicated a Speed Sensor issue and my Tachometer was wildly spinning; my mechanic swapped my gauge cluster and my TCM after doing a complete ECU continuity check. These items were swapped several months back, and nothing new has been worked on the car. I have the old TCM in my trunk.
Unfortunately, I was unable to remove the terminal, because I don't have the tools handy. However, I was able to pull a code with the diagnostic mode, 5 long 5 short, but the A32 CEL decoder does not list this code, a search on this forum indicates it's a healthy code.
I'm not sure that statement was completely accurate, but I do know, that I was not passing 70mph on the highway and the tachometer was almost at my redline. Whenever I released the acceleration, the car slowed down much faster than usual, such as if I were in a Low gear (1-2). Sorry, I can't provide great test explanations, I'm not by any means; mechanically inclined. I do have some open road around, that I can try to examine on, but I'm at work, and deeply concerned because later on I have school.
Old Jul 9, 2009 | 03:55 PM
Agh, I think it was user error :P
It's possible I accidentally kept it in 2nd gear in my whole commute this morning. I guess these sleepless nights are gonna cost me a lot one day. But Today, is not that day!
Old Jul 9, 2009 | 04:17 PM
pmohr's Avatar
No more Maximas...
Indeed, near redline at highway speeds is 2nd gear.
Old Jul 9, 2009 | 08:08 PM
I almost had a good reason to do a 5spd swap, or even a 6spd :P
Old Jul 10, 2009 | 06:47 AM
njmaxseltd's Avatar
Ahhhh, A classic case of PEBOAV.
Problem Exists Between Operator And Vehicle.
captchaos
Mar 15, 2016 12:18 PM
slowlifer
Sep 8, 2015 05:53 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
