Car won't start, i need some help
Old Jul 14, 2009 | 09:34 PM
Maxima287's Avatar
i have a 96' with a de-k in it and for some reason when i turn the key nothing happens, it doesn't turn over. When i checked the wire going to the started with my test light, it's not even getting power when i turn the key. .
Old Jul 14, 2009 | 09:38 PM
Maximeltman's Avatar
Is ur battery dead? is it connected? does ur engine even try to crank?
Old Jul 14, 2009 | 09:46 PM
Maxima287's Avatar
the battery is good and it doesnt crank or do anything...it just makes a buzzing sound and thats it but when i jump the starter it cranks so i know the starter is good.
Old Jul 14, 2009 | 10:12 PM
aackshun's Avatar
This buzzing sound? Is it coming from under the dash? Sounds like what I had... I just cleaned my battery terminals w/ some coke and my car starts up now, but I'm going to do some real work on the terminals tomorrow afternoon, to ensure that this problem never happens to me again.
Old Jul 14, 2009 | 10:49 PM
pmohr's Avatar
No more Maximas...
There is a lot of information missing here.
When did it start not cranking? Since you put the DE-K in? Just recently?
Did you do anything to the car immediately prior to this, did you have anything done, or did anything happen?
Since you didn't give any details, are we to assume that you're still an automatic? Have you tried starting it in every gear range, not just Park or Neutral?
Which wire did you check? The signal wire that's got a connector on it, or the B+ feed that bolts on to the solenoid?
What exactly is buzzing? Have you checked all the connections to the starter and at the battery, making sure they're all tight and making good contact (corrosion free)?
Old Jul 15, 2009 | 06:40 AM
Maxima287's Avatar
the buzzing sounds like its under the hood but when listening from the outside it sounds like its in the car....... and PMOHR its still the same car i was PMing you about but i decided to make a thread because i haven't gotten a response, it turned over last week when i cleaned the terminals but now the B+ wire that goes to the starter is dead (not getting any power to it) and the car isn't auto anymore
Old Jul 15, 2009 | 06:42 AM
pmohr's Avatar
No more Maximas...
Honestly I discuss so many different cars and starting issues over PM, I would have to read back through them to remember anything.
So the B+ feed to the starter isn't getting power? Have you followed it back to the battery? It's a very short run, it shouldn't be dead.
Old Jul 15, 2009 | 06:58 AM
Maxima287's Avatar
yea i took all the tape and loom off and the wire goes right to the clutch interlock relay.
Old Jul 15, 2009 | 10:10 AM
kisas's Avatar
try jump start see if it's battery,
then see if you get enough voltage for the ignition
Old Jul 15, 2009 | 10:59 AM
Maxima287's Avatar
i tried to jump start it and still isn't doing anything.
Old Jul 15, 2009 | 11:00 AM
pmohr's Avatar
No more Maximas...
The B+ feed should not go there, it should go straight to the battery. Are you talking about the signal wire then? Completely different things.
Have you bypassed the clutch interlock relay to see if it'll start? Jumped the starter manually?
Old Jul 15, 2009 | 11:21 AM
Maxima287's Avatar
lol sorry...the signal wire is what i meant. i bypassed the clutch interlock and even got a new relay. and i jumped the starter manually but it doesn't turn over as fast.
Old Jul 15, 2009 | 11:30 AM
pmohr's Avatar
No more Maximas...
As fast as?
If it's not turning over quickly, and you've already verified that the battery is in good shape, then have you checked what sort of voltage you're seeing at the starter itself? Corroded or loose connection?
Old Jul 15, 2009 | 12:37 PM
Leo_Koneval's Avatar
We should make a sticky with all starting problem scenarios and offer solutions right on that thread for each scenario haha
But by buzzing do you mean like a ticking sound or clicking sound? Because if there is a sound then I think your battery is just really low. I hope, hahah
Old Jul 16, 2009 | 10:11 AM
Maxima287's Avatar
the blk and red wire that plugs into the starter doesnt have any power when i put my test light to it.
Old Jul 16, 2009 | 10:23 AM
pmohr's Avatar
No more Maximas...
Is this while you have the key turned to the start position? If not, it shouldn't have voltage.
Old Jul 16, 2009 | 02:24 PM
asand1's Avatar
Have you ched for signal at the relay? if none pull the column plastic and check at the switch.
Old Jul 16, 2009 | 02:29 PM
Maxima287's Avatar
yes i have the key turned when i check that wire.
Old Jul 16, 2009 | 05:43 PM
asand1's Avatar
Here are some things to check first. Dont forget to check ALL fuses. GL
Old Jul 18, 2009 | 05:24 PM
DAVE Sz's Avatar
Hooooooonda.....
Originally Posted by pmohr
As fast as?
What voltage should I be seeing at the starter and when should I see it? I see battery voltage when key is in ON posiion and then a 5-7v drop when I try to start the car...
Old Jul 20, 2009 | 11:14 AM
cdelena's Avatar
I found it took both a new starter and starter relay to resolve my starting problems. It is common to have intermittant relay problems so it is hard to test for... I wasted a lot of time and should have just replaced both parts to begin with.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
