Fuel Pump Control Module Ghost code????
Old Jul 21, 2009 | 11:56 AM
Stagnet04's Avatar
Ok heres the deal, I did an AUTO to 5 SPEED swap on my 98 Max and everything is good, I used a 98 manual ECU but now im getting a 0513 "fuel pump control module" code, BUT nothing is wrong with the car.... No stalling, no fuel problems, drives perfect, eveything seems to be ok.... I did some research and eveyone that has this code, has some type of problem so thats why I dont think it could be the actual fuel pump or relay....Is this just a "ghost code"? is there any way to get rid of it?
From what Iv seen the best way to resolve it would be to change the ECU, but is there a certain production date that I should look for or serial number.... Im really stumped on this one....Any help with this would be much appreciated....
Oh and I have reset the ECU about 6 times and the code comes back within 2 days, EVERY TIME!
Old Jul 21, 2009 | 12:58 PM
djipka's Avatar
anything older than 98 will do
Old Jul 21, 2009 | 01:02 PM
Stagnet04's Avatar
See whats weird is that I had a 97 SE ECU before I put the 98 ECU in and it gave me the same code.... could it possibly be the fuel pump even though Im having no mechanical problems whatsoever?
Old Jul 21, 2009 | 01:49 PM
pmohr's Avatar
No more Maximas...
No, the fuel pump has nothing to do with the FPCM (from a DTC standpoint).
Are you sure you're reading the codes correctly? The FPCM code P1220 is 1305, not 0513.
The only years to have an FPCM are '96 and '97 (well '95 Cali did, but not monitored by the ECU). '98 does not have one, and a '98 ECU does not have the capability to throw that code. Exactly how sure are you that the ECU is from a '98?
You're throwing the code (assuming you're reading it correctly) because you have a '96 or '97 ECU, and your car never came with the FPCM; it's not there, so the ECU throws a code.
Old Jul 21, 2009 | 02:05 PM
Stagnet04's Avatar
Yeah that's what I meant 1305. Your absolutley right about the ECU, I'm not 100% sure it's from a 98, I was told it was. I'm currentley calling junkyards to see If I can find a 98 ECU. Has anyone else had this problem swapped tranny or not?
Thanks....
Old Jul 21, 2009 | 03:21 PM
pmohr's Avatar
No more Maximas...
Thanks....
There are a few people that I can remember responding to that have had this happen, from putting in the wrong ECU.
http://forums.maxima.org/4th-generat...ol-module.html
http://forums.maxima.org/2760939-post2.html
http://forums.maxima.org/4th-generat...ap-my-car.html
...etc
Old Jul 21, 2009 | 03:40 PM
Stagnet04's Avatar
...etc
Yeah I saw those, It looks like im gonna try to switch the ECU, if that doesnt work, then im in a world of hurt, cuz the last thing I want to do is spend a ton of money trying to fix something that Im sure is small....
Old Jul 21, 2009 | 03:48 PM
Stagnet04's Avatar
oh BTW, do you know if the production date matters? or as long as its a 98 ECU, it should be ok?
Old Jul 21, 2009 | 03:50 PM
pmohr's Avatar
No more Maximas...
Any '98 should work just fine. Or a '95, those may or may not be easier to find.
Old Jul 21, 2009 | 10:17 PM
djipka's Avatar
95 all the way. saves a lot of headaches and swearing
Old Jul 22, 2009 | 11:57 AM
Stagnet04's Avatar
Did I read you guys correctly? a 95 would work? I thought those werent a direct fit for the 98 harness.
oh would a 99 work or would there be other CELs coming up?
Old Jul 22, 2009 | 12:09 PM
pmohr's Avatar
No more Maximas...
A '95 will plug in and work just fine. You may have to switch around a pin or two on the connector to avoid CELs for the rear O2 sensor.
The '99 has a different pinout, and the NATS system; won't work (easily).
Old Jul 22, 2009 | 12:11 PM
Stagnet04's Avatar
Ahhh, ok I got you....
Thanks....
Old Jul 24, 2009 | 01:02 PM
Stagnet04's Avatar
Actually, one more question, If I can just move a few pins around from the 95, can I just do the same with the ECU I have now 97'? If so, do you have any info on this?
Thanks....
Old Jul 24, 2009 | 01:10 PM
pmohr's Avatar
No more Maximas...
Thanks....
You mean to get rid of the FPCM code? No, not without actually having an FPCM (or doing some electronics work to trick the ECU).
The wires I was referring to earlier are just signal and heater wires for the rear O2, IIRC.
Old Jul 24, 2009 | 01:12 PM
Stagnet04's Avatar
damn.... oh well I guess I have to look for the 98' ECU,
Thanks for the quick response....
Old Jul 24, 2009 | 11:02 PM
Stagnet04's Avatar
The wires I was referring to earlier are just signal and heater wires for the rear O2, IIRC.[/quote]
^^^^Anyone know how to do this exactly? modify the 95 ECU wiring so it fits a 98 manual and not throw the rear o2 sensor code?
I couldnt find anything....
Old Jul 24, 2009 | 11:06 PM
pmohr's Avatar
No more Maximas...
Wait, what? I thought you have a '98, and are trying to put in a '95 ECU? The way you said it, you're implying the opposite.
There is no 'wiring' associated with the ECU, everything there is all tracks on a PCB. What you do is repin the ECU harness connector on the car. You could open up the ECU, cut the pins, and use some wire, but that's not nearly as easily reversible as the connector repin is.
Anyway, did you look at the pinouts for both years? The heater is 2 pins off.
Old Jul 24, 2009 | 11:15 PM
Stagnet04's Avatar
Yeah, I have a 98 max, with a 97 ECU right now, so if I get the 95' ECU, I can do this re-wire or re-pin thing and be ok right? I dont care if its reversible, as long as it makes the CEL go away im cool with it....
Im still gonna be looking for a 98 5 speed ECU, but I want to keep this as a solid option cuz for some reason, I can find a 95 5 speed ECU pretty easily....
Nah I havent looked at the pinouts of the ECU yet.
When you say "re-pin" are you talking about cutting off the 2 pins and basically soldering them on another spot?
Old Jul 24, 2009 | 11:17 PM
pmohr's Avatar
No more Maximas...
Then that's what you need to do, if you want to figure it out.
You could do that, but it's kind of hackish. All of the pins are easily removed from the connector and swapped around.
Old Jul 24, 2009 | 11:23 PM
Stagnet04's Avatar
Yeah, ill scope it out....
LOL! at this point I really dont care, as long as it works. If I can find a 95 5-speed ECU at a good price, I think ill be down....
Old Aug 8, 2009 | 07:55 AM
Stagnet04's Avatar
Just to let everyone know, Pmohr was absolutely right about this situation. I swapped out my 97' ECU for a 98' ECU 5 speed and NO MORE CODE! This should be part of the 5-speed swap stickie, cuz before I did my swap, I couldnt find any info/warning about this situation. If not, no big deal, I just wont delete this thread....
Thanks again Pmohr....
Old Sep 28, 2010 | 09:43 PM
allstar3004's Avatar
Bumping this thread because I have a 98 Maxima with the same problem. I'm trying to find a 98 Maxima ECU to replace the one I have now but I'm having trouble locating one.
Can I just buy a FPCM and install it to get rid of the ghost code? How difficult is the install?
Old Sep 29, 2010 | 02:42 AM
pmohr's Avatar
No more Maximas...
You could, but you'd also have to run wiring for the FPCM and the drop resistor to have it set up like factory to the point it wouldn't throw the code. This would involve running a wire from the ECU back to the trunk and tapping into the fuel pump wiring there, along with obtaining an FPCM and drop resistor.
Easier (and better) to just get the correct ECU for your application.
Old Sep 29, 2010 | 04:43 AM
Trini Boom's Avatar
If you have problems finding the correct ECU, PM maxfever1987 as he is always stripping 4th gens.
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
rnb754
Sep 14, 2015 11:39 PM
dcam0326
Sep 7, 2015 07:26 AM
