maxima not cranking
Old Dec 8, 2021 | 11:27 PM
  #41
HAL2021's Avatar
Originally Posted by JvG
Many many starting issues are due to problems with the electrical portion of the ignition switch.
Those are a known issue our cars have.
Replacement is not difficult. The part costs about 30 dollars.
Thank you, I wanted to go that way!. But when I did the electrical test with a light probe. I stick the probe into the feed wire that connects to the grey wire on the solenoid. As I turn the key to start I saw the probe LIGHT-UP. So it was my conclusion I am getting power. Do you think in regards to this evidence I still need to change it.
Old Dec 8, 2021 | 11:32 PM
  #42
HAL2021's Avatar
Originally Posted by Zerodrag
I've actually installed a new starter from either advance auto or autozone that worked the first day but stopped working after that. I brought it back and they tested it on their bench as good. I still requested they give me a replacement (was a gold line unit so probably autozone?) and that one worked out.
In short, the bench test probably doesn't address all potential issues with a starter.
Just my $0.02..
Thank you, I heard that a lot. Problem the original is testing GOOD, and the new ONE is testing GOOD. I replace one of the new one already. So Pep-boys I think when you buy their starter you can't return back.
Old Dec 8, 2021 | 11:43 PM
  #43
KP11520's Avatar
Originally Posted by HAL2021
"Today's world is farther from logic than ever. More like ill informed opinions rule." Agreed. That's what happen when you take GOD out of the it. You're lost!. (Remember the story of Noah and his Son)
Thank you, with all honestly, that was the first thing I tried.
Amen on that!
Since you tested the positive routes, I'm wondering if it's on the negative side that there's a gap/disconnect somehow? And the starter is BOLTED to the engine. Maybe back to the ignition side. Ground breakdown in the column?
Old Dec 10, 2021 | 11:02 AM
  #44
JvG's Avatar
JvG
An iffy connection can pass enough amps to light a test bulb. Yet not enough to activate the device the wire is supposed to power.
You might want to attach a test wire to the positive terminal of the battery. Then touch that wire to the solenoid contact on the starter.
The starter might crank as it should. That would indicate that the battery and starter are healthy. Also that the problem is most likely the ignition switch
Roymg
Aug 15, 2018 12:14 PM
AZMaxima53
Dec 31, 2017 04:40 AM
slowmanvns
Nov 4, 2017 05:19 PM
vpr
Mar 15, 2015 10:05 AM
Dreizehn
Jun 4, 2001 10:59 AM
