Double Take On Cranking
Old Aug 14, 2018 | 10:37 AM
Roymg's Avatar
Have an 03 Maxima GLE. Sometime when engaging the ignition switch the first time I get nothing (no starter engaged). Second time I get an engaged starter and good to go. Looking at the circuit you have a battery, ignition switch, start relay, a transmission start neutral switch, and finally the starter. The battery is good as is the transmission start neutral switch, and the start relay, under the hood ( I replaced new. )
So have any of you guys had this problem? Does the starter have it's own integral relay? Could it have bad
brushes or commentator? Only thing with this starter, which is original, is it cranks fine. Maybe the switch part of the ignition switch could be the culprit? It doesn't appear that this 03 will leave me stranded.
Old Aug 14, 2018 | 11:19 AM
DennisMik's Avatar
I think the ignition switch in the steering column is having a problem. This is not all that unusual at all.
Old Aug 14, 2018 | 11:26 AM
Roymg's Avatar
Yes, I'm leaning that way too, thanks for the input.
Old Aug 14, 2018 | 12:03 PM
Child_uv_KoRn's Avatar
Bad *** Newb
you'll get stranded if it's the starter solenoid and you don't know how to jump it :P
Old Aug 14, 2018 | 02:01 PM
User1's Avatar
Starter is on it's way out. Will need replaced soon. Keep a hammer with you to tap the starter until then.
Old Aug 14, 2018 | 09:10 PM
CMax03's Avatar
Is it an Automatic? If so see what happens if you don't unlock the shifter and move it rearward....Then see if it doesn't start....Now push the shifter forward and if it starts it's your safety neutral safety switch needs adjusting on the Shifter!
Old Aug 15, 2018 | 12:09 PM
Roymg's Avatar
Yes is an automatic and it will only start in park or neutral.
Old Aug 15, 2018 | 12:11 PM
Roymg's Avatar
I don't think so...starter starts with vigor...yeah, I know about the hammer trick.
Old Aug 15, 2018 | 12:12 PM
Roymg's Avatar
Nope sure don't...would be AAA time.
Old Aug 15, 2018 | 12:14 PM
Roymg's Avatar
A back switch block from Nissan is about $58.
AZMaxima53
Dec 31, 2017 04:40 AM
vpr
Mar 15, 2015 10:05 AM
ZIPPIN
Jul 7, 2007 09:53 AM
chillin014
Feb 23, 2007 08:01 AM
jarrod91se
Mar 5, 2004 09:31 AM
