do I have 2 bad o2 sensors?
I changed my knock sensor and I thought that would fix my flat 3k rpm power, it did help a little but now I have p0153(left bank) and p0133(right bank). Which one's are these and how difficult are they to replace. Thanks.
You prob need to change them. the front 2 aren't that bad unless you live in a place where they salt roads or your exhaust is incredible rusted. Do you have a stock Y-pipe?
I'll probably just change the 2 that are giving me problems right now, where are the 2 bad o2 sensors locations at? Does autozone borrow/rent that special socket and lastly where can I get the cheapest/compatible o2 sensors?
The location of the O2 sensors you need to replace are on the downpipes from the manifolds, on the Y-pipe itself. With a stock y-pipe you won't have as much room as with aftermarket, but it won't be hard.
And check oxygensensors.com
