Anyone here had experience with Auto-RX? need your opinions
Old Aug 16, 2009 | 02:00 PM
kisas's Avatar
For those of you 4-gen guys who have experience with auto-rx, I have 2 questions:
1. did it really work on your engine, what improvement you got ?
2. will it cause further oil leak after application?
I read some testimonials about auto-rx, not sure if those stories are "commercials", I would like to confirm its effectiveness here.
My car has 122k on the engine, it has oil leak, lose half a quart in 1k. I don't expect auto-rx can fix it, but i don't want it get worse. any opinions? thanks!
Old Aug 16, 2009 | 02:20 PM
manny097's Avatar
I think this product is just like any other product you find at any auto parts store. How can a liquid fix a leak, it may clean but not seal a leak. Lift you're car up access the leak, go from there
Old Aug 16, 2009 | 02:22 PM
kisas's Avatar
it's an internal leak
Old Aug 16, 2009 | 02:44 PM
manny097's Avatar
OK if its internal, the oil has to go somewhere, Coolant, is there white blueish smoke coming out of youre tail pipe
Old Aug 17, 2009 | 03:10 PM
ajm8127's Avatar
If you already have a leak, then I would fix that before using auto-rx. This product gently cleans out your lubrication system. It can actaully cause leaks by removing deposits on seals that have been deformed. That is why they tell you to run a change of dino oil through after the treatment, to recondition the seals.
It is a good product though, but its not designed to seal leaks.
Old Aug 17, 2009 | 05:44 PM
kisas's Avatar
thanks! I took my car to a mechanic today, pretty much sure it's the worn-out piston which caused the leak and burning oil.
It seems that there is not way to make the oil leak go away, unless replace engine.
Old Aug 17, 2009 | 08:29 PM
caseymaxima's Avatar
I had no leaks when I got my 96 three years ago, and it had 80,000 miles on it. Just on a whim I used the Auto RX, because I was not sure how often the original owner changed the oil. Did I do anything for my car, I have no clue? I could not tell any difference. I followed their directions to the letter.
Zack
Old Aug 18, 2009 | 06:03 AM
max ride 41's Avatar
some snake oils work to a degree, i think bg engine treatment works well in my engine to keep rattle to a minimum. i've also used mothers seal tightener in oil with some sucess, just remember they're only a quick fix and not a permanant one and keep up on maintenence and you'll be ok.
Old Aug 18, 2009 | 06:13 AM
njmaxseltd's Avatar
The only thing that should be in your crank case is engine oil.
Everything else is simply marketing 101.
Old Aug 18, 2009 | 06:35 AM
DanNY's Avatar
Ad·min·is·tra·tor
i've used it...seems like it clean the motor out since the oil was super dark after 1000 miles but i never seen any deposits in the filter or anything.
Old Aug 18, 2009 | 05:52 PM
atriuum's Avatar
I'm thinking of using some 0w-30 Syntec in October.... Off topic, but closer to getting those thread starting privileges...
Old Aug 18, 2009 | 06:27 PM
ajm8127's Avatar
Read the Bob the Oil Guy forums sometime.
Old Aug 19, 2009 | 01:07 AM
tosheto's Avatar
Auto RX is good stuff. I have used it and will use it again. The oil leak is other deal though
Old Aug 19, 2009 | 07:20 AM
ThreePointO's Avatar
i used auto rx, didnt see much of a difference.
Old Aug 19, 2009 | 08:08 AM
kisas's Avatar
what year is your car?
Old Aug 19, 2009 | 08:10 AM
kisas's Avatar
The only concern for me is if auto-rx will make the leaking worse.
REDinLV
Aug 15, 2024 12:30 AM
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Pied
Sep 26, 2015 03:29 PM
dvcamp
Sep 18, 2015 10:17 AM
