Anti-seize for Spark Plug Threads?
Old Sep 22, 2009 | 06:54 PM
wxm's Avatar
wxm
Just wondering what kind of anti-seize do you use for the spark plug threads (if any at all)? While I was replacing the plugs, I have noticed that the threads were quite rusted. Advise appreciated as always.
Old Sep 22, 2009 | 07:26 PM
ajm8127's Avatar
I used the same kind on the plugs that I use on everything else. Permatex sells it in a gray metal tube. Keep it only on the threads and you should be fine.
Old Sep 22, 2009 | 08:35 PM
Definitely put some anti-seize on the threads of the plugs. IIRC there isn't any special anti-seize for plugs only.
Old Sep 27, 2009 | 12:00 PM
JackMeUp's Avatar
Hi-temp Permatex anti-seize. I use the copper one with the paintbrush built into the lid. I think there's another one (black?) that's even higher-temp rated. If you use this on every bolt you remove you'll be glad you did if you do a lot of wrenching on the car. Especially in areas where they use a lot of road salt.
Old Sep 27, 2009 | 12:30 PM
blongthao's Avatar
anyone know y i can't post???
Old Sep 27, 2009 | 12:33 PM
You need 15 posts in order to make a thread. (http://forums.maxima.org/feedback-su...rt-thread.html)
Read up on this sticky:
http://forums.maxima.org/4th-generat...e-posting.html
Old Sep 27, 2009 | 03:45 PM
pmohr's Avatar
No more Maximas...
...you just did post
You'll find many opinions on both sides of the argument, whether or not to use it. No manufacturer that I'm aware of has ever used it from the factory, says enough to me. Personally I never use it, and I've never had a problem getting plugs out of those vehicles years later.
Old Sep 27, 2009 | 07:38 PM
CMax03's Avatar
Yes it's a good thing!
Old Sep 28, 2009 | 03:14 AM
dgeesaman's Avatar
Maintenance Monster
Spark plugs come nickel plated on the threads. The nickel shears off and acts like nickel-based anti-seize.
If your threads are in good shape therefore there is no need for anti-seize. But adding it won't hurt.
Old Sep 28, 2009 | 03:35 AM
nismology's Avatar
I skip it lest I overtorque. Overrated.
Old Sep 29, 2009 | 05:59 AM
wxm's Avatar
wxm
Good point!
Nice to know.
Old Sep 29, 2009 | 10:46 AM
Coolsaber57's Avatar
I do it as a matter of habit. We always had 15+year old hondas that had problems getting the old plugs out because the MF grease monkeys who changed the plugs (before we owned the cars) put them in too tight and the slightest bit of rust/whatever fused them to the threads. Talk about a PITA.
I get the stuff at the counters at Advanced Auto (little gray packets).
Old Sep 29, 2009 | 10:55 AM
cashoit's Avatar
Whenever i refer to the haynes manual it says to add anti-sieze compound...thats good enough for me. Dont matter what brand u use, jus make sure to get the stuff for use with spark plugs
Old Sep 29, 2009 | 01:40 PM
Kickin_Wing's Avatar
Copper Anti-seize on the threads, dielectric grease on the terminal. Not required, but usually recommended.
Old Sep 29, 2009 | 01:49 PM
chris1984's Avatar
i use it to me makes it easier when time to replace them
Old Sep 30, 2009 | 02:27 PM
dgeesaman's Avatar
Maintenance Monster
With a spark plug it should be torqued using turn of the wrench to compress the crush washer to the correct amount. The only way to overtorque them is to turn the wrench around too much and flatten the washer completely.
David
Old Sep 30, 2009 | 05:33 PM
nismology's Avatar
Granted that I've never overtorqued a plug due to using anti-seize, I'm generally more conscientious than I used to be regarding torquing and whether or not the spec reflects application of a substance. It just happens to spill over to this. I still contend that it is an overrated and unnecessary step.
Old Oct 2, 2009 | 01:53 AM
throttlehappy46's Avatar
Using anti-seize is beneficial when your alloy head is hot, as it can allow you to remove a spark plug with some heat in the engine rather than changing spark plugs first thing in the morning on a dead cold motor. Seen a few people strip spark plug threads removing spark plugs on a warm motor.
Another thing is that a blown headgasket can push water up the thread under compression and cause the spark plug to rust in place as well.
I am quite happy to use a small dab of ARP grease, since I usually end up with heaps of that left over on an engine build anyway lol
Old Oct 2, 2009 | 05:13 AM
96i30azn's Avatar
wuh i just put some normal ones... is it gonna bust my engine?
edit - nvm the package(which i threw away) had a picture of spark plugs so i guess it better not blow up my engine.
Old Oct 3, 2009 | 08:23 AM
Les7311's Avatar
help out!
anyone has a write up with pics how to change the plugs for an 05 maxima???
Old Oct 3, 2009 | 10:15 AM
Fail.
Wrong section. Search. Get a Haynes Manual.
Old Oct 4, 2009 | 05:48 AM
wxm's Avatar
wxm
Search in with 5th Gen Maxima forum.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
