Hella Air Horns Installation: Use Relay or Not?
Old Nov 30, 2001 | 03:56 AM
FL Robert's Avatar
I read what seems to be two options on th eMegaMax web site regarding installing Hella air horns for the Maxima. At one point Jeff Ketch points out that there's a short cut where you can forget about the relay and just plug a male connector from the stock horn switching into the compressor, and then ground the compressor. THe detailed instructions, though, show the use of the relay.
I've noticed that otehr users ahve this mod -- how did you guys do it? Is one way preferable to the other?
Old Nov 30, 2001 | 04:41 AM
Confused's Avatar
Permanent Maxima.org Resident
use the relay and don't forget to blow the horns the next time someone is looking under your hood
Old Nov 30, 2001 | 04:44 AM
Sprint's Avatar
Old Nov 30, 2001 | 07:10 AM
1Phat Max's Avatar
Re: Hella Air Horns Installation: Use Relay or Not?
i have heard so many ppl installing air-horns without using realys...i have them installed but i used relays to install them. I also did an install on my friends civic without any relays splicing straight into stock wires. But that kept blowing fuse, so what we did was put in 15 amp fuse instead of 7.5. And it has been working perfectly since witout blowing any fuses. hope this helped!
Old Nov 30, 2001 | 07:27 AM
1MAX2NV's Avatar
YES if you are planing on holding it down for more than 1 second...
I did it both ways. Without relay, you can honk the horn < 1 second. Everything will be fine. If you hold the horn for more than 1 sec, you will blow the fuse.
Old Nov 30, 2001 | 08:10 AM
clee130's Avatar
Use the relay. If it's in the box, it's there for a reason.
And yet, do like Confused says and give someone a nice surprise the next time they have their head inside your engine bay.
Old Nov 30, 2001 | 08:43 AM
matty's Avatar
NO NO NO NO NO NO
You only have to use the relay if you are keeping your existing horns...if you not, just take the old horns out, put the new ones in, make sure to ground them and happy horning
Old Nov 30, 2001 | 09:00 AM
ny96max's Avatar
YOU MUST USE A RELAY!!!
the relay supplies the compressor a full 12volts from the battery direct. Keep in mind a relay is an electronic switch, so when you hit the horn you trigger the relay to open and give the compressor the full 12volts it needs to operate correctly!! There is no way a compressor can operate off just the existing horn wire. Even if it did work they would not be operating to their full potential.
I would reccomend taking out both of the stock horns and replacing them with the new airhorns. Then all you need to do is grab the source wire from one of the horns and run it into the relay along with a power wire from the battery direct(with inline 15amp fuse), then ground the relay and run the output of the relay to the compressor. It should be all layed out for you on the instruction sheet. You will need a few connectors too that fit the relay to make wiring alot easier.
any other questions just ask
Anthony
Old Nov 30, 2001 | 09:08 AM
1MAX2NV's Avatar
Re: NO NO NO NO NO NO
Push and hold your horn down for 5 seconds. Let us know what happens.
Old Nov 30, 2001 | 09:15 AM
clee130's Avatar
Re: Re: NO NO NO NO NO NO
With my relay in, I held it down for 1 minute ... while following some jerk-off who cut me off.
Yes.... bad "road-raged" moderator... BAD!
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
