How do u replace these
Old Oct 16, 2009 | 05:24 PM
VQphantom's Avatar
Heres some pics.......Its the bent up tube
Old Oct 16, 2009 | 05:27 PM
pmohr's Avatar
No more Maximas...
They're pressed into the head, but good luck getting it out.
Old Oct 16, 2009 | 05:31 PM
VQphantom's Avatar
So they are possible to get out right?
Old Oct 16, 2009 | 05:33 PM
pmohr's Avatar
No more Maximas...
Theoretically, yes. In practice, you end up just tearing it up. Keep on working at it, eventually you'll get it out.
Looks like it's on the block, if you can get the head off and take it to Frank, I'm sure he can pop it out rather easily.
Old Oct 16, 2009 | 05:37 PM
Conrad283's Avatar
I need a truck
What are you doing, and how did you know something was wrong?
Old Oct 16, 2009 | 05:49 PM
VQphantom's Avatar
Im doing a small build and trying to see what kinda power/track times i can get out of it. i bought this motor and had it sittin in my house for a awhile and when i remove the valve cover the tube was slightly bent .Then i called my self trying to get it out and it got worst.lol
Old Oct 16, 2009 | 05:55 PM
Conrad283's Avatar
I need a truck
I see ... What type of build?
Is it a VQ30?
Old Oct 16, 2009 | 06:04 PM
VQphantom's Avatar
Im thinking about doing 3.0 heads on the 3.5 block maybe some new rods and pistons, headers , mevi and exhaust .
Is it a VQ30?
Old Oct 16, 2009 | 06:16 PM
Shift_Knob's Avatar
why not just get a metal cone and tap it in with a hammer??
Old Oct 16, 2009 | 06:56 PM
Conrad283's Avatar
I need a truck
Cool, good luck.
Old Oct 16, 2009 | 07:25 PM
VQphantom's Avatar
I was thinking about that but where do i get such a tool lol or thingy ?
Old Oct 16, 2009 | 07:41 PM
Q8BallMAXIMA's Avatar
Could you use a metal funnel and shape a dowel on the end to match the funnel angle and stick the dowel end into the funnel and tap the flat side of the dowel with a hammer? Might be worth a try?
Old Oct 16, 2009 | 07:57 PM
JNCoRacer's Avatar
Just the tip.
Hardware store. Its a weighted tool used to make sure something is vertical. I cant think of the actual name of it, but its hung by a piece of string or wire.
Old Oct 16, 2009 | 07:59 PM
MOHFpro90's Avatar
Its called a plumb bob (sp?) IIRC
Old Oct 16, 2009 | 08:00 PM
Feldman's Avatar
plumb bob
Old Oct 16, 2009 | 08:26 PM
VQphantom's Avatar
Lmao for some reason this tool is funny to me but ok interesting...... A plumb bob i'll look it up
Old Oct 16, 2009 | 08:32 PM
Feldman's Avatar
i think it could work for you but i would also use a pipe or dowel or pretty much anything else rigid that barely fits inside the tube. Once you use the plumb bob to round the opening use the dowel or whatever you find to finish it off or else you will split the tube
Old Oct 16, 2009 | 09:07 PM
VQphantom's Avatar
Oh ok thanks for all the input here I'll the suggestions and i'll be back with the pics
Old Oct 16, 2009 | 11:53 PM
Shift_Knob's Avatar
i have a exhaust pipe expander thats basically a iron cone that you hammer in the end of the pipe thats where i got the idea from. the plumb bob is a good idea but most of the time they are made from brass that would prob to too soft to be very effective here. if you can find a steel or stainless plumb bob that would work better. another option would be a pair of pliers and just bend it back little at the time. just keep working your way around the tube. who cares if it is scratched up no one will see it but you and it done have to be 100% round to seal just as long as the socket and plug will fit in the hole.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
