ah man, starting problems again?!?!
Old Oct 19, 2009 | 11:35 AM
burgundyblues66's Avatar
ok, so here are the details. i have had starting problems on and off for a while, once or twice it was the fuel pump and then it was the ecu, which i replaced.
now, here are the symptoms. ill be driving, and when i slow down to stop i will push in the clutch and the rpms will fall to near zero, it will sputter, and then level out around 500 rpm. basically, it almost dies whenever i stop. also, it doesn't start sometimes when the engine is warm. if i stop to park, turn it off, and decide to move it a bit closer, it wont start. if i wait a few hours, there is no problem. its like not enough fuel is getting to the engine, has anyone had this happen?
Old Oct 19, 2009 | 12:02 PM
JtzMax's Avatar
Whatchyou say?
I've had simmilar issues. Mine turned out to be a vaccumm leak at the MAF. One of my hoses slid off of my CAI and my car did the same thing. Check your MAF (plug too) and intake (especially if you have a CAI). Have you tried the 'normal stuff' like cleaning the IACV / TB ??? I'd do that also, even if you don't find any problem. Also, check your air filter - replace it if need be. Go from there and get back to us. G'luck!
Hope this helps.
Old Nov 18, 2009 | 08:18 AM
romicva's Avatar
How do I know if starter is goind bad?
Battery and alternator seem ok, however it takes longer to start My Maxima 99 GXE with AT.
Thank you.
Roman.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
Tha'-Max
Aug 30, 2015 01:14 AM
