car won't start suddenly
Old Nov 5, 2009 | 09:33 PM
kv2's Avatar
kv2
Hey guys i'm here for some help again..
Ok so very randomly today when i started my car, i heard this pretty loud weird noise coming from under the hood. it was a consistent low whirring noise, hard to describe. anyway i pulled out of the driveway and into the street and it disappeared so i made nothing of it.
Everything normal when i got to work. But come time to go home, i can't start the car anymore. All the lights, radio, highbeam, etc work fine. When i turn the key.... silence. engine doesn't turn, no click noise, nothing. also want to mention i changed the starter a couple months ago.
any sugguestions?
Old Nov 5, 2009 | 09:41 PM
smai555's Avatar
ignition switch, neutral safety switch,
do u have auto or manual?
Old Nov 5, 2009 | 10:27 PM
kv2's Avatar
kv2
it's a manual.
Old Nov 6, 2009 | 06:02 AM
pmohr's Avatar
No more Maximas...
Originally Posted by kv2
it's a manual.
Is this a factory 5MT, or a swap?
If you jiggle the key while in the start position, does it try to start?
Do you have the factory security system? If so, have you tried to unlock the driver's door with the key to make sure it isn't keeping you from starting the car?
Do you have an aftermarket security system, remote start, or a starter kill?
Have you checked the Start Signal fuse in the fuse box? Shown here on the right, in between the O2 sensor and fuel pump fuses:
Are you sure you're pushing the clutch all the way down? Have you tried bypassing the clutch switch?
Have you tried jumping the starter manually to make sure it even works?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
Gsantos79
Aug 8, 2015 07:41 AM
