timing chain install question(s)...
Old Jan 6, 2010 | 12:31 PM
max ride 41's Avatar
ok other than the main chain, water pump, rtv sealant, guides and tensioners, do i need to replace the 2 sprockets the chain sits on?? im thinkin no, but i was told they have to see it when it is apart. anything else im missing? anyone near collegeville pa. that can help me out with install? thanks in advance>
Old Jan 6, 2010 | 12:45 PM
ATTappman's Avatar
There is a specification for the camshaft sprockets - the runout has to be less than 0.15mm. If it's above that they need to be replaced.
I've got no idea how common it is to replace them, but there is a runout spec.
Old Jan 6, 2010 | 08:18 PM
pmohr's Avatar
No more Maximas...
The main chain rides on 3 different timing gears, not two (both intake cams and the crank). Personally, I've never seen the need to replace them (nor the chain itself, but you seem to already be set on that).
Any reason you're replacing the chain?
Old Jan 6, 2010 | 10:11 PM
well, its been rattling at start up for several minutes, it does get quiet eventually. and i was told that since i am doing the water pump soon that it has to be removed anyway. some op say just do tensioners and maybe guides but its at 200,000 miles and i want to keep it for another year or 2.
Old Jan 6, 2010 | 10:31 PM
95arcticpearl's Avatar
Correct me if I'm wrong but from what I've read the chain shouldn't have to be replaced only the tensioner and the guide need to be replaced to stop the rattling. I haven't done this my self (I plan on it soon because I have the rattling also) but from what I've read that's what my plan of attack is going to be when I do the job.
Old Jan 7, 2010 | 07:20 AM
njmaxseltd's Avatar
You really only need to replace the tensioner, shouldn't be that hard to do along with the water pump. They have an updated tensioner for your 95. The rattle will be gone.
Old Jan 7, 2010 | 05:56 PM
which tensioner is updated? i dont need to do the guides? what about the seals? front cam seals need to be done? please specify, thanks>>>
Old Jan 8, 2010 | 12:37 AM
FallenOne's Avatar
Hey got a quick question for ya guys while this topic is up; when you replace your tensioner does it free up a significant enough amount of length to say swap cams?
Old Jan 8, 2010 | 04:56 AM
pmohr's Avatar
No more Maximas...
In order to remove the cams you would need to remove not only the main chain, but also both secondary chains, as well as the timing covers and/or the cam gears.
Old Jan 8, 2010 | 04:59 AM
pmohr's Avatar
No more Maximas...
The main tensioner had an updated model. The main guide should also be replaced with the new revidion.
There are no cam seals.
Old Jan 13, 2010 | 12:37 PM
timbrooks77's Avatar
I have good pics of front of engine with timing chain cover off. If you need them for reference.
Old Jan 14, 2010 | 08:33 AM
ineedamaxima's Avatar
I'll take them! please email them to kevinbrandon at hotmail.com
Cheers,
Kevin
Old Jan 14, 2010 | 08:15 PM
add them to the thread if you would. i've seen the inside many times, but never had good pics to stare at, thanks.
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Team STILLEN
Aug 10, 2015 04:29 PM
mikekay
Aug 10, 2015 12:52 PM
