Engine cuts at 2,000 revs
Old Jan 11, 2010 | 12:41 PM
gallilaw's Avatar
My 1998 SE manual tranny experienced many ghastly pre-death rattles today.
The engine runs fine until it hits 2,000 revs, at which time it cuts out, with no trouble lights coming on. Makes no difference what gear I'm in; if I push any gear to 2,000 revs, bang. The engine will turn on and off, in lurching spurts, dying at 2,000 and surging at anything below that (if I let it surge, rather than accepting life as it is, backing off the gas, and driving slowly).
Below 2000, the engine still sounds great.
Checked the oil. No temperature problem.
Any ideas?
Thanks.
Old Jan 11, 2010 | 12:54 PM
Product_Of_Korea's Avatar
sounds like the maf to me.
Have you done anything recently to your car?
Old Jan 11, 2010 | 12:55 PM
Blackwind's Avatar
codes? CEL? need more info.
Old Jan 11, 2010 | 12:59 PM
internetautomar's Avatar
mod or sell?
definitely sounds like a MAF issue.
Old Jan 11, 2010 | 01:45 PM
Kevlo911's Avatar
Kevlo for President
Def the MAF, please search
Old Jan 11, 2010 | 04:23 PM
gallilaw's Avatar
When I got some time I ran a check using an OBD II system I bought recently. It showed only one trouble code: PO 3 25, relating to a knock sensor.
I'll do some research on the MAF, but wonder why that would not show up if the MAF was at fault. Maybe it needs to have more time in trouble?
Old Jan 14, 2010 | 10:27 AM
cashoit's Avatar
try some MAF cleaner and clean the TB. That should help
Old Jan 14, 2010 | 11:22 AM
luke95gxe's Avatar
Any ideas?
Thanks.
def sounds like maf sensor i had some issues with mine a while back ended up being the the wires in the connector so i cut it and soldered them right on the pin fixed the problem
Old Jan 14, 2010 | 11:50 AM
Snypa's Avatar
MAF
Old Jan 15, 2010 | 08:58 AM
pavelsmax's Avatar
MAF
+1
make sure the harness is plugged in, i've made this mistake before after working on my car......
Old Jan 15, 2010 | 09:16 AM
maximariceboi's Avatar
yes maf related issue...but i had the same problem with my 99 a year ago and it actually came out to be a egr problem..randomly cuts off at 2000 rpm..turn the car off and start it up..it was fine....no egr with the 3.5 swap at the time..put the egr in and now im still codeless
Old Jan 15, 2010 | 07:05 PM
Nismo32's Avatar
Any ideas?
Thanks.
turn the car on disconnect the maf see if there is any change. then disconnect one sensor at a time from the iacv. if still the same be careful. i had the same issue and my problem was the actual ECU.
shilov
Feb 19, 2024 09:40 PM
bryants95max
Oct 2, 2015 12:52 PM
seesole
Sep 14, 2015 12:38 PM
nbstriker10
Sep 4, 2015 04:26 PM
TheMafia
Sep 4, 2015 08:26 AM
