View Poll Results: Car Doesn't Seem to Warm Up On the Gauge...
Voters: 24. You may not vote on this poll
Car Barely Warms Up; Is that good or bad?
I notice that my car barely reaches the warm spot on the gauge and hangs out either Cold or a fraction above it, even after driving it hard for 30-40 minutes. I have an intake and the engine bay gets alot of cool air, especially not that it's like 20 degrees in Jersey regularly.
I also notice that the heater doesn't get really hot either. If the temperature goes up warm, the heater works well... If it remains in the cold side, the heater barely warms up.
Is this a problem?!?!?
Wow. 2 minuntes is really quick. i live in colorado and wait a good 5-7 minutes before driving. its halfway warm by the time i start driving. I used to get some bad hesitations if it wasnt all the way warm but i got a used maf and that seemed to fix the problem
Well if you want the heater to blow warm air all the time, you need to get a new stat or a higher temp stat..i would think that your max might run a lil sluggish that cold maybe a lil rich...I replace mine every winter i use a 185-190 deg..and summer time i put a 160-165 deg stat in....but thats just me
I havent had to replace my thermostat sine the car came off the lot in 1995 haha, unless they replaced it as part of the service on the waranty and i dont member...Maybe im lucky but replacing the thermostat in ANY car once a year is overkill...
i just changed my thermostat today. i had the same issue as you, op. only my car heated to normal temperatures, then after say an hour of driving on the highway, it dropped to cold. my heat went away. i would come to a stop and it would rise back to normal temp, and my heat would come back.
i changed the thermostat, and it runs fine.
Possible Thermostat issue too
My car takes a lil while to warm up. But eventually does warm up. I have never had a problem with heat but when i am on the highway..the gauge temperature drops below normal then goes back to normal when i come to a stop. the car also seems to be leaking coolant from that area but i have been unable to find the leak.
Do i need a thermostat?
I thought that too....but the engine doesnt overheat or anything. It jus drops a little below normal. How can i tell its the waterpump. My mech can do the job but has been unable to diagnose himself. He is not a nissan dealer so i think thats why he hasnt really found da problem. Besides...i can ride on a bad pump for a long time wit these cars.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Maxboy23
Aug 11, 2015 11:59 AM
