Fuel Injector cleaning kit (where to hook it up)
Old Jan 22, 2010 | 08:38 AM
Justaguy's Avatar
Hi,
I'd like to clean out my fuel injectors by buying those canisters that hook up to the fuel rail. (You hook it up, remove the fuel pump fuse, start-it up and wait till the can is empty).
I think run-rite had such a kit but can't seem to located it (still looking).
Here's my question, where would I hook this this up to, the top or bottom of the fuel filter? Or somewhere else?
Thanks...any other recommendation is welcomed (p.s. only directly attached fuel line, not crazy about gas additives)
Here's the product:
http://www.run-riteracing.com/industry/9677.html
Old Jan 24, 2010 | 10:12 AM
Justaguy's Avatar
Okay got my own answer, it would need to hook-up with the fuel line that is coming out of the fuel filter.
Now there's another problem..I need a OTC fuel injection adapter so that the canister can hook up to using air pressure. Anyone know which adapter to get?
thanks
Old Jan 25, 2010 | 11:27 AM
cashoit's Avatar
have u read my chevron techron thread :P lol
Old Jan 25, 2010 | 12:15 PM
Justaguy's Avatar
yup I did.
And I think still that the best way is to use a air pressure canister to unblock the injectors.
Also, you can't get chevron techron up here in Canada.
The local garage is going to charge me $100, might just get it done there.
Old Jan 25, 2010 | 12:23 PM
cashoit's Avatar
Originally Posted by Justaguy
yup I did.
Since using the stuff, I turned into a Chevron spokesman lol
Why u doing the cleaning? What problems u havin, or jus doing some preventative maintenance?
100 bucks seems a little steep for somethin that only gonna take an hr at the most.
Old Jan 26, 2010 | 08:45 AM
Justaguy's Avatar
It's just preventative maintenance. The car has 190,000kms and it was never done.
Yup, it's a tad expensive, but this is Montreal where taxes are 15% and payroll taxes are 46% and gas is at $1.10 a litre ($4 a gallon)...
I was going to do this myself but I don't know what kind of adapter I need to get to hook it up to the fuel line.
Old Jan 26, 2010 | 09:46 PM
BORQUA79's Avatar
nycmaximas member
humm chevron techron thread.... I gotta see this???
Old Jan 26, 2010 | 11:12 PM
deadlydreamx's Avatar
hmm ive done multiple fuel injector cleanings at my job and we use run-rite but the bottle you have there is a lil diff than what i use. the bottle we use is somethin like this
http://www.run-riteracing.com/industry/9600.html...
i usually hook it up to the brake booster hose n let it do its magic
Old Jan 27, 2010 | 10:16 AM
Justaguy's Avatar
deadlydreamx: THANK YOU!
Yup it's a little different...do you still hook it up to the air compressor?
brake booster hose?
I have no idea where that is...can it still be hooked to the hose coming out of the fuel filter from the bottom?
Old Jan 27, 2010 | 07:36 PM
nah you dont need air it works on vacuum. the silver cone thingy at the end of the line goes into a vacuum line and that sucks the fluid in the bottle little by little into the intake and it cleans ur manifold and injectors apparently. I did it to my car and i didnt really notice anything but then again my car is well maintained
Old Jan 27, 2010 | 08:23 PM
JNCoRacer's Avatar
Just the tip.
That? I dont even want to know how much that costs.
Old Jan 28, 2010 | 07:29 AM
Justaguy's Avatar
Anyone kind enough to show me where this vaccum or brake boaster hose is located?
Old Jan 28, 2010 | 10:48 AM
nhaven's Avatar
Old Jan 28, 2010 | 01:43 PM
Justaguy's Avatar
thanks, I needed that...now where does it suck it in...the little black piece or where you wrote booster.
Great help!! THANKS!!!
Old Jan 28, 2010 | 04:34 PM
jholley's Avatar
Don't unhook the hose at the brake booster. The brake booster check valve cannot take any liquids. Unhook the hose to the left of the brake booster check valve (the tiny black plastic valve with a rubber boot).
Old Jan 28, 2010 | 10:42 PM
defiance's Avatar
Where is that ? point to it
Old Jan 29, 2010 | 04:43 AM
jholley's Avatar
The booster check valve sits where vacuum line is written below
[/quote]
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
seesole
Sep 14, 2015 12:38 PM
aminus21
Sep 12, 2015 04:53 PM
