Why does rain makes my car lose power? MAF?
Old Feb 1, 2010 | 10:19 AM
Saunter's Avatar
Whenever I drive for more than 20mins while its raining the car's power will fluxuate and start studdering. I have K & N CAI but its been doing that before I changed stock filter. Any suggestions what I should check?
When its not raining no starting or stalling problems at all, which makes me question replacing MAF sensor. I'd hate to pony up the money for new MAF if I don't have too
Old Feb 1, 2010 | 10:26 AM
smai555's Avatar
when its dry and somewhat dark out ... warm the car up open the hood and spray a mist of water over different parts of the engine... im guessing youll see some arc-ing , where ever you see arcing the wires need to be replaced
this is the test i used to do to check spark plug wires i would think this should work in this case
Old Feb 1, 2010 | 10:36 AM
Saunter's Avatar
Ok thx I'll try that
Old Feb 1, 2010 | 03:58 PM
cartman854's Avatar
Thats a very good idea, lol.
Old Feb 1, 2010 | 04:16 PM
MaxiBronxBomber's Avatar
Originally Posted by Saunter
Whenever I drive for more than 20mins while its raining the car's power will fluxtuate and start studdering. I have K & N CAI but its been doing that before I changed stock filter. Any suggestions what I should check?
Sunter, you should have ignition coils, no wires on the spark plugs. It sounds electrical,check the coils to see if one of the boots may have broken or become too pliable. You should also check underneath to see if the starter ground wire could be a naked or corrosion being it only happens when it rains. That's my advice, it happened to me. I replaced the coils and my baby rides strong.
Good luck!
Old Feb 1, 2010 | 11:03 PM
iflossdaily's Avatar
I agree with MaxiBronx. I don't think that spraying water in your engine compartment will produce anything. There are no rotors or spark plug wires in our cars. (Or any Japanese car since the 80's).
Old Feb 1, 2010 | 11:13 PM
HandsonMaxima.'s Avatar
so my friends 94 integra is...? Chinese?
Old Feb 2, 2010 | 04:54 AM
Nealoc187's Avatar
SLOW
My money is on water messing with your coilpacks, either by getting in your spark plug tubes somehow, or shorting out the connectors.
On my old beater max, I had no screws holding my coilpacks down (and the cover that covers them was long gone). Because of this, the coilpacks would gradually wiggle their way a little loose on the spark plugs (over the course of a few weeks or a month or whatever). In moderate to heavy rain, I'd start to get a little bit of hesitation and surging. Pop the hood, press coilpacks down firmly into the spark plug tubes, problem gone for another month.
BTW, tons of Japanese cars have had spark plug wires and distributors since the 80s. Whoever made that claim is flat out wrong.
Old Feb 2, 2010 | 05:11 AM
cashoit's Avatar
Ok im kinda fuzzy here....how is it possible to get rain water on the coils if the hood is down??? Is the OP ridin with no hood?? thats gangsta lol
We need more info here....where exactly did the OP place the CAI filter?
Old Feb 2, 2010 | 08:25 AM
slow_yota's Avatar
E - ownage on maxima.org happens yet again.
Old Feb 2, 2010 | 08:27 AM
Saunter's Avatar
MaxiBronx and Nealoc187 called it right, when checking coilpacks on the rear firewall side 1 of the boots was broken so bad the tube was exposed.
Thank you for your help
Old Feb 2, 2010 | 08:02 PM
You're right. I stand corrected.
Old Feb 28, 2010 | 06:40 PM
mkzg's Avatar
Other cars it woudl be wires. Im guessing you have one or more bad coilpacks.
Old Feb 28, 2010 | 11:46 PM
saylee's Avatar
lol..that made me giggle..
maybe it is your maf sensor bro... does your idle stay steady at a stop?? my friends 95 toyota had a similar problem in cold weather, it got even worse when he put a cold air.. After he changed his MAF, his car ran good even when it would rain or on really cold days.. i dont know, hopefully this helps
Old Mar 1, 2010 | 10:16 AM
Nealoc187's Avatar
SLOW
he already figured it out, it was a split coil boot like some of us suggested.
i won't even bother to answer the question about how water can get on the coils. if the guy who asked that question can't understand that the engine compartment is not hermetically sealed, then there's no amount of explanation that can make him understand that water gets in to places when you're flying down the road and it's getting splashed and sprayed everywhere by wheels, hitting the radiator and dribbling through it, etc.
Old Mar 4, 2010 | 08:49 AM
K31J1m0N's Avatar
maximas hate water...gotta love it
Old Mar 4, 2010 | 12:38 PM
Saunter's Avatar
Driving with no hood that's funny, yep only the days I'm feeling getto lol
I changed the coil but haven't drove in rain yet so not sure if that's da fix but it needed to be changed anyway.
It stays steady when idle at 500 with slight movement sometimes to 550 600 then stays at 500 so it could be MAF but not sure if that little movement warrants it being bad, I'll look for used MAF here just in case, if anyone has one PM me.
I took out my cluster and tightened all the screws to make sure that's not effecting the needle and all the screws were not that loose but none were tight either
Thanks for help and suggestions
Old Mar 5, 2010 | 09:26 AM
BlueBlackMax's Avatar
yeah my 93 Mazda 626 had a distributor lol
Old Mar 5, 2010 | 10:55 AM
cashoit's Avatar
Lol Driving with no hood that's funny, yep only the days I'm feeling getto lol
It stays steady when idle at 500 with slight moment sometimes to 550 600 then stays at 500 so it could be MAF but not sure if that little movement warrants it being bad, I'll look for used MAF here just in case, if anyone has one PM me.
Both my cars had that slight flutter on RPMs. YO man, as long as it idles between 500-600 then u good. I think she running good man. might jus need the big 3 clean..TB, MAF, and IACV. ( EGR tube if u really feeling industrious )
Im feelin frisky and bored and moro supposed to be in the low 50s, so ima do the big myself
Lakersallday24
Jun 16, 2019 01:35 AM
JRod28
Feb 4, 2016 11:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
altome15
Aug 10, 2015 07:05 PM
acw
Aug 7, 2015 04:20 PM
