Clutch Issue
Old Feb 24, 2010 | 09:01 AM
Infowire's Avatar
Clutch Issue
So when the car is off i can switch to any gear, but when i start the car i cant get into any gears... what could it be?
There is plenty of clutch fluid. Could this be a bad clutch? or something else?
Old Feb 24, 2010 | 10:05 AM
luke95gxe's Avatar
sound like the clutch may be bad get some one in the car and have them push the clutch and u watch to see if the slave cylinder pushes the fork
Old Feb 24, 2010 | 10:24 AM
cashoit's Avatar
clutch or pressure plate or linkage. Somethin is broke in there.
Old Jun 20, 2010 | 02:42 PM
CK913's Avatar
having same problem, any one have solution?
Old Jun 22, 2010 | 04:13 PM
luke95gxe's Avatar
see if the the slave cylinder is pushin the clutch fork if it is then its clutch plate or pressure plate if its not pushing the fork u have air in the lines or master or slave cylinder are shot lift the hood and have some one push the clutch a few times see if the slave cylinder moves
Old Jun 22, 2010 | 07:36 PM
j-dawg's Avatar
Bleed your line, if you have someone to help you. I thought there was plenty of fluid in mine, but it turned out it's replacing the fluid with air from the leak instead of with fluid from the reservoir. I have to bleed the lines every time I add fluid, or it just sits in the reservoir as though the lines were blocked.
Old Jul 20, 2010 | 08:40 PM
keil's Avatar
im haveing da same problem after doing some crazy burnouts, so i checked da slave cilinder movement was good ,then bled da line and it was da same so da only thing it could be is da preasure plate or da throw out bearing *max dem out*
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
