Transmision S.O.S.
Old Mar 1, 2010 | 05:07 AM
wgray's Avatar
Transmision S.O.S.
My 95se shifts fine through 1st and 2nd gear but does not go into drive or overdrive I checked
fluids and everything is good. Is this a tranny swap or is the trans repairable?
Old Mar 1, 2010 | 08:39 AM
1992maximase30's Avatar
so it just stays in 2nd gear. does'nt attempt to go into 3rd? what about reverse? do you have reverse?
Old Mar 1, 2010 | 08:54 AM
cashoit's Avatar
Sounds like an electrical issue, like a faulty Tranny solenoid. It sounds almost like the Tranny jus doesnt recognonize when its in Drive.
If u remove the Shifter panel, ther should be some cables down there. Make sure wires and grommets not worn.
Old Mar 1, 2010 | 03:36 PM
wgray's Avatar
I have reverse and the selector is in drive. The car just goes through 1 and 2 smoothly and rpms shoot up with no drive or overdrive. It just stays in 2nd gear and revs too find drive but doesnt. I can drive with the selectorin 2nd no faster than 20mph in 2nd gear and rpms at about 2100.
Old Mar 1, 2010 | 05:52 PM
but it still pulls? or does it slip at higher speeds?i ask because when i first got my 4th gen it either had 1st-3rd, 2nd only, 1st and 3rd. but no reverse.
so if there's no slippage then it could be the shift linkage.
Old Mar 1, 2010 | 06:05 PM
wgray's Avatar
It pulls no slipping just 1 and 2 gear
Old Mar 1, 2010 | 06:20 PM
Fasteddie01's Avatar
the FSM AT-74 also indicates it could be the inhibitor switch adjustment (#1), control linkage adj (#2), etc. Have you checked these ?
Old Mar 1, 2010 | 07:00 PM
Rob_0126's Avatar
Does it go over 2100 rpms in 2nd?
btw, what year is the car?
Old Mar 1, 2010 | 07:47 PM
95 se it says.
Old Mar 2, 2010 | 03:56 AM
wgray's Avatar
yes it can go over 2100 in 2nd gear
Old Mar 4, 2010 | 10:18 AM
hmm...it's possible the cable is in the wrong position. does the od light flash?
Old Mar 4, 2010 | 03:49 PM
wgray's Avatar
No flashing OD light
Old Mar 4, 2010 | 07:31 PM
yea it's gotta be the shifter cable then.
oh yea check your fluid...well the color and smell of it.
but my eye is on the shifter cable.
Old Mar 5, 2010 | 01:20 AM
wgray's Avatar
Thanks I will check and post results
brcron007
Nov 28, 2013 02:13 PM
macakin
Sep 2, 2013 07:29 PM
johnnyd2k2
Aug 7, 2008 10:19 AM
Guinader
Jun 19, 2005 04:16 PM
Gamezilla
Nov 17, 2001 01:52 PM
