So it wasn't my coil packs..
Old Mar 19, 2010 | 09:16 AM
Mistertones's Avatar
I searched and tried the method of pulling each coil plugs out one by one to see if there is no shuddering. I got shuddering for every coil I pulled out. I'm assuming that means all my coils are functional. The reason I did that is because I get a lot of hesitation and RPM drops when I'm merging on to a high way. When I am accelerating it won't go much faster. It hits around 3K then it drops. Any ideas on what is wrong? I cleaned the MAF sensor a week ago. To see if that would help, it did not. No CEL on currently or when I scanned my ECU. I'm thinking it could be a faulty MAF, but I could be wrong.
Old Mar 19, 2010 | 09:28 AM
JwaxMax99's Avatar
Possible MAF, swap on a friends MAF to rule it out.
Old Mar 19, 2010 | 09:35 AM
None of my friends own a Maxima =(. Closes person with a Nissan is my Sisters 04 FX45. I doubt that would work though.
Old Mar 19, 2010 | 09:40 AM
done12many2's Avatar
I would not rule out the coil packs. I suspect mine are failing under load. They may function fine at idle, but when a load is placed on the engine, they may behave differently.
Old Mar 19, 2010 | 09:41 AM
ajm8127's Avatar
You don't have to swap it to check it. Just read the voltages off of like like is described in the FSM.
Old Mar 19, 2010 | 09:43 AM
I actually pulled the MAF plug while the car was on and scanned my ECU and it did throw a code for that. Does that mean the MAF is working or no?
Old Mar 19, 2010 | 11:07 AM
xkazik's Avatar
no, that just means ur ECU detected that it was disconnected . check if the voltage is in specs or change mafs.
Old Mar 19, 2010 | 11:19 AM
rizzindriver89's Avatar
+1 on replacing maf/checking maf.
Mine acted up and no codes were popping up. The only code I ever got was a IAT sensor but after the maf was swapped out it behaves perfectly.
Also, clean TB thoroughly with a tooth brush. MAF cleaner does very little in my opinion though
Old Mar 19, 2010 | 06:29 PM
trooplewis's Avatar
When was the last time you replaced your fuel filter?
Old Mar 19, 2010 | 08:27 PM
mahanddeem's Avatar
or fuel pump
Old Mar 19, 2010 | 10:29 PM
Never replaced fuel filter or pump. Original owner kept ever maintenance in a Excel file.
Old Mar 20, 2010 | 09:48 AM
Quickywd01's Avatar
Is there anywhere else in the FSM that shows or explains how to test the coils besides EC-421. If you could list the section and page.
Old Mar 25, 2010 | 07:43 AM
Cleaned out the throttle body the other day. Man was it dirty, The inside was caked up inside with so much dirt/debris. It helped with my problem a little bit. But the sluggish acceleration is still there. I've been scanning my ECU and hoping for something to pop up to give me an idea.
Old Mar 25, 2010 | 12:16 PM
SiathLinux's Avatar
I would love to have a copy of the layout they used... if possible to siath@live.com
OP - did you work out the solution to your hesitation - as I've seen several threads about this issue, esp. in 'later' 4th Gen ...
Old Mar 25, 2010 | 12:23 PM
Hey I'll send you the excel file when I get home from the office. But I have not found a solution. Cleaning the TB did make a difference in acceleration though.
Old Apr 5, 2010 | 10:48 AM
Questions could it be a slipping clutch?? It's hard for me to accelerate. The RPMS would climb high then drop, but i barely gain any speed.
Old Apr 5, 2010 | 10:58 AM
aackshun's Avatar
You seem to be having a slipping clutch, while the OP does not.
Old Apr 5, 2010 | 07:04 PM
rf97's Avatar
wrap each coil pack's boot with electric tape, then drive car as you normally do and see if notice any difference. I was able to determine my problem with a defective coil pack by performing this trick.
Old Apr 6, 2010 | 02:53 AM
Trini Boom's Avatar
I have never heard of this trick and exactly what would this show us?
Old Apr 6, 2010 | 06:21 AM
cashoit's Avatar
Never hrd of this .... . I guess the point is to hold the coil together with tape to determine which is broken ???
Mistertones,
It sound like u got a slipping clutch. If the RPMs jump high when u switch gears then finally catch, then clutch is worn.
Old Apr 6, 2010 | 07:26 AM
IlyaK's Avatar
The Golden One
I suggest fuel filter and seafoam in the brake booster line in addition to the coilpack voltage test and MAF test.
Here is my file if you want it:
http://www.ilyakol.com/Maxima/Maxima%20Maintenance.xls
Old Apr 6, 2010 | 04:20 PM
Mistertones,
That is what I feared. A slipping clutch . Do you know the typical cost to replace a clutch? I've googled around people say it could cost from 400-2800.
Old Apr 7, 2010 | 09:44 AM
Ok so I just checked my clutch fluid, and it was wayy below the min line. What does that mean?
Old Apr 7, 2010 | 10:21 AM
Augustus Maximus's Avatar
It means top it up. If it ain't leaking, you got a worn friction disk. Changing the clutch is something you can do yourself. The hardest part is convincing yourself that you can do it.
Old Apr 7, 2010 | 11:10 AM
I've read around, So I use DOT 3 brake fluid to top it off?
Old Apr 9, 2010 | 02:43 AM
So I added more more fluid still drives like crap. I'm picking up a Saschs clutch tomorrow and getting it replaced for 300 bucks.
Old Apr 9, 2010 | 06:06 AM
cashoit's Avatar
If it is leaking fluid then u have either a a torn hose or a faulty slave and master cylinder. Since the car is old, u shd replace all three. Do it once, do it right
Old Apr 9, 2010 | 02:16 PM
I got this Exedy Clutch today. It looks pretty decent. My friend hooked me up for 90 bucks.
Old Apr 12, 2010 | 05:34 PM
So I finally got the car back today. MAN it is a big difference with the clutch. The car goes so much faster. No more lag or anything. So changing the knock sensor, cleaning the TB, cleaning the MAF, running injector cleaners made the car feel faster then when I got it a year ago. But questions, the clutch engages a lot high then before, is that normal? Also my clutch pedal isn't as still as before, is that normal as well for a new clutch and resurfaced flywheel?
Old Apr 12, 2010 | 09:15 PM
HandsonMaxima.'s Avatar
its normal for a stiffer clutch, wait till you do a SS clutch line. when i depress mine i can feel the engine fighting the clutch. and its normal for the pedal to be harder to push, the pedal is probably engaging higher because you had air in the clutch line they bled out.
Old Apr 13, 2010 | 02:59 AM
I mean my clutch pedal is not as hard to push down. It is very easy to push down not much effort. Is there a way to make it a little stiffer? I'm used to have to push a little harder. With this new clutch, It will take time getting used to. I stalled out 2 times
Old Apr 13, 2010 | 07:53 AM
im not positive, the only non oem clutch ive driven on was in my friends spec 4 clutch integ. pressing it down was like trying to smash a can.
you can try bleeding it but i would think it should be harder to push.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
