Removal of EGR FLow Sensor
Old Apr 10, 2010 | 11:26 AM
rdw72777's Avatar
So I'm in the process of doing the EGR Guide tube cleaning, and I've gotten to the step where I remove the EGR flow sensor from the assembly.
While I know this might not be a necessary step, it is in my case as I need to get it out of the way so I can unclamp some hoses that some idiot clamped on with the clamping mechainsm on the bottom (i.e. i cant get my pliers in there to unclamp the hose)
So my question is this, how do people break the nut on the EGR flow sensor. Its a 14mm nut, and I'm trying like hell with a wrench. Can't get a socket on the not because the sensor is attached/built into the nut.
Any other tools a novice like me might not know about?
Old Apr 10, 2010 | 11:34 AM
ZachAJ's Avatar
I just did this today.
First, you can spray something like PB on it to loosen up stuck bolts.
To get it off, I used a 14 double sided wrench...they usually have a little angle to them, which helps in tight situations like this. Your ratcheting wrench won't work because of that cable. You can try an adjustable monkey wrench too, but it's not as good...
Old Apr 10, 2010 | 11:35 AM
ZachAJ's Avatar
By the way, be very careful when you're hacking that bolt not to hack the coolant line directly above it...that's what I just did....it's only like a $4 part from Courtesy, but it means no Maxi for a week till the part comes in.
Old Apr 10, 2010 | 12:46 PM
rdw72777's Avatar
I've removed just about everything there is to remove to get to the hacking bolt. I'm on my second hacksaw blade. I'm not sure what point I will give up, the bolt, as poorly designed as it is (too long), is stronger than Superman.
Old Apr 10, 2010 | 12:51 PM
nhaven's Avatar
You can try hitting the wrench with a hammer if you have enough room.
Old Apr 10, 2010 | 01:51 PM
FallenOne's Avatar
PB blaster, 3 Hours of sit time.. Patience with a crescent wrench.
Old Apr 11, 2010 | 08:33 AM
Afterlife's Avatar
once you get the egr off just plug the holes and leave the sensor plugged in to the harness you wont have to worry about cels or worry about cleaning it again.
Old Apr 11, 2010 | 10:13 AM
rdw72777's Avatar
So you're saying...
...Remove the EGR guide tube once and for all and just plug the holes where the EGR guide tube used to attach? Is that recommended, haven't heard that one before?
Old Apr 11, 2010 | 11:56 AM
FallenOne's Avatar
Its done every single day, EGR on these cars is unnecessary, i know plenty of people on here pass inspection with blocked off EGR's.. hell i did. Than again mine's blocked with Carbon to the point that i don't need block off plates.. bahaha.
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxboy23
Sep 4, 2015 06:04 PM
Justin Kroll
Sep 2, 2015 11:06 AM
