HELP my 96 maxima wont turn on
Old Apr 18, 2010 | 08:35 AM
96MAXIGLE's Avatar
So I went to turn my Max on and all I hear is the starter spinning no roar to turn on...I have new battery. Starter was changed in December..I don't know was wrong wit my baby help please
Old Apr 18, 2010 | 08:58 AM
Trini Boom's Avatar
If you hear your starter spinning and your engine not turning over, you only have two options. Its either your starter or your battery was drained and does not have enough juice.
Old Apr 18, 2010 | 09:41 AM
96MAXIGLE's Avatar
I do have 2 amps in my car but the battery Is new my starter is still under warranty
Old Apr 18, 2010 | 10:00 AM
Speedy13's Avatar
had a problem like this and had to have my key reprogrammed.... something to think about
Old Apr 18, 2010 | 05:18 PM
95maxse3000's Avatar
i would take a starter back and get a new one. when you take it out check the teeth on the starter and the fly wheel make sure there all there. take the battery and put it on a charge make sure its not drained a little from the amps.
Old Apr 19, 2010 | 06:53 AM
Try to give it a boost before replacing the starter.
Old Apr 19, 2010 | 07:05 AM
yeah give her a good boost first.
Old Apr 19, 2010 | 08:54 AM
rdw72777's Avatar
Multimeter
What readings are you getting? With your "rotating electrical" system its gotta be the battery/starter/alternator as that's all there is.
If we're down to battery/starter, let us know the readings on each. If they are both within spec, maybe check battery cables for corrosion...
Old Apr 19, 2010 | 09:32 AM
cartman854's Avatar
Heres what to do to eliminate battery
If you have another vehicle, and like 20mins, take out the battery, and take it to your local battery sales store, and ask them to load test it and charge it, they should do this for free. If its all good, then you know it is the starter, also if you pop off the fuel filter, when you turn the key see if it shoots gas everywhere to know that your getting fuel.
Old Apr 19, 2010 | 02:48 PM
96MAXIGLE's Avatar
starter
Thanks guys it was the starter
Old Apr 19, 2010 | 05:26 PM
no surprise there.
Old May 9, 2010 | 12:34 PM
illmortal's Avatar
Bump!
If your car takes longer (winds longer) to start, even with a brand new battery, new fuel filter, and spark plugs, does that indicate that the starter is going? Can coil packs also give this sort of symptom if they're going out?
My car just started this problem this morning. I even went as far as conditioning the battery with a battery charger but my car still takes a couple-three seconds to crank when previously as soon as my key hit the limit of the turn (in the ignition), my car would instantly turn on and very quietly. Now as it's trying to crank... it's sort of loud and literally takes about 2 sometimes 3 seconds to finally crank.
Old May 10, 2010 | 08:28 PM
Trini Boom's Avatar
Originally Posted by illmortal
Bump!
What's your year and mileage?
Old May 10, 2010 | 10:41 PM
aackshun's Avatar
Do you hear your fuel pump when you leave the key in the "On" position? (it's pretty quiet, so you have to be in a silent area and listen to a low whirr).
I have a long starting problem too, I've narrowed it down to it being a bad FPR, I also blame the FPR for my stumbling under sudden throttle changes (Haven't replaced it yet due to my lack of care/laziness, I have more important things to deal w/ on the car than that).
trasmadean
Feb 1, 2017 08:20 PM
acw
Aug 13, 2015 12:50 AM
Flores94
Aug 11, 2015 12:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
