do i need this sensor in my air filter?
someone added a after market air filter on my max and drilled a hole in the center and added a sensor i have no clue what it is but it has a 2 wire eltrical clip.
do i need it when i switch filters?
it its like this o0o going into the front (fender side) it just is a sensor to check temp. If you dont want it there, ziptie it nearby, it just needs to check temp, and doesnt have to be in mail stream of air.
it probably just gives a heads up to the ECU and lets the comp adjust a bit more quickly to differences in temp than it would without it. The O2 sensor and MAP sensor would fill in the blanks if the Intake Air Sensor were out of the loop.
JoshG
51
09-21-2015 10:41 PM
97_GXE
20
09-17-2015 08:12 PM
sdotcarter
09-02-2015 09:53 PM
