The Blue or Pink Wire?
Old Jun 1, 2010 | 12:58 PM
Justaguy's Avatar
Hi,
In my non-bose speaker system, there are two wires going to my speakers via the harness, the blue and pink wire...which one is the negative?
Old Jun 1, 2010 | 01:01 PM
darklegend06's Avatar
get a ohm reader and it should tell you. It's a great investment.
Old Jun 1, 2010 | 04:41 PM
EsQueue's Avatar
The only way is to check the FSM. An ohm reader is worthless for speakers as the polarity changes back and forth.
Old Jun 1, 2010 | 07:08 PM
OC_Nooby's Avatar
You have 2 wires going to your speakers or speaker? If speakers then I have no clue...Its 2 wires per speaker.
The terminal on the speaker itself should be marked with a + and - or sometimes its just one of them.
In any case:
http://www.nicoclub.com/archives/4th...ing-codes.html
Enjoy.
Old Jun 2, 2010 | 01:53 PM
xsmooth69x's Avatar
oc +1 wire harness diagram what everyone needs
Old Jun 2, 2010 | 04:50 PM
Justaguy's Avatar
Thanks OC..yes it's 2 wires per speaker. I checked the speakers and harness and there is no indication of a + or -
Funny that the other rear speakers has 2 different colored wires..can't remember right now since I'm at work.
I'll study the diagram given.
Old Jun 2, 2010 | 07:27 PM
ampire's Avatar
Right Rear (+) Blue Right Rear (-) Pink
http://ccs.exl.info/carwires.html
Also reversing polarity shouldn't kill your system, it will just make your speaker cone move the opposite direction of what it should, and it wouldn't sound right (out of phase / reversed polarity,etc).
Old Jun 3, 2010 | 06:48 AM
cashoit's Avatar
Justaguy,
Out of curiosity, why are u clipping only the negative wire? If u replacing the speaker u need to clip both
Old Jun 3, 2010 | 09:28 AM
Justaguy's Avatar
Thanks... Pink is the negative.
Cashoit: The speakers that I just bought, the harness doesn't quite fit, the terminals are about 1 inch apart, so I need to clip the wires or get an extender.
Old Jun 3, 2010 | 12:03 PM
cashoit's Avatar
yeah i figured u was replacing speakers. I replaced all mine with kenwoods. Had to cut all the olf factory speaker harness and splice new connectors.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
