INSANE OVERHEAT!
Old Jun 24, 2010 | 08:20 PM
scmaxima's Avatar
INSANE OVERHEAT!
Ill make it short... basically the ECTS is snapped but it still fits so i just stuck it in there temporarily.. i changed my waterpump and tstat like 2 months ago, everything was fine..
like a week ago i turn on the car, feels funny and i saw the coolant backpressured to the reservoir tank??? so it moved from the rad to the reservoir. i moved it back and it was ok.
3 days later, the car had a lot of trouble starting, cranks all day but doesnt start, and very weird noises, next thing i notice, overheats like crazy....
i turn it off, then for the last 2 days, everytime i turn it on when its very cold, it'll just warm up and like 3 minutes later, overheats like crazy even tho the rad is full and reservoir is perfect
the codes i have are 0707 0908 0103 1005 0705
so mainly EGR valvue, ECTS?
im going to sell the car ASAP and going for an 06 g35s so jump in if you have any prior knowledge or experience..
Old Jun 24, 2010 | 08:42 PM
scmaxima's Avatar
guys come on.. i need help =/
Old Jun 24, 2010 | 08:54 PM
hornepirate's Avatar
egr has nothing to do with overheating. Change out that ECTS and it should solve your problem.
Old Jun 24, 2010 | 08:56 PM
scmaxima's Avatar
u think thats the only problem??
Old Jun 24, 2010 | 09:02 PM
urmab's Avatar
check your thermostat it might of stuck closed
Old Jun 24, 2010 | 09:08 PM
scmaxima's Avatar
ok, ill get right on the tstat.. and hmm i doubt that a bad ects would cause all of this.. the car overheats and the radiator smokes !!
Old Jun 24, 2010 | 09:41 PM
96nismoSE's Avatar
the fans might not be kicking in do to the bad ects
Old Jun 24, 2010 | 09:43 PM
youd be surprised how much trouble a bad ECTS can cause. I had it go in my car before. I know
Old Jun 24, 2010 | 10:17 PM
stamar's Avatar
um blown head gasket
look at the oil for mud
Old Jun 25, 2010 | 03:27 AM
max ride 41's Avatar
ummm, yeah, head gasket is a good possibility. but, check your oil first, and your rad fluid.
Old Jun 25, 2010 | 06:19 AM
99zx2's Avatar
yeah, man. make sure the fans come on and go buy a new sensor, it's less expensive than dealing with a blown hg. Also check your t-stat.
Old Jun 25, 2010 | 07:12 AM
cashoit's Avatar
check tstat and eCTS. SOmetimes tstat cant be installed backwards.
Old Jun 25, 2010 | 07:35 AM
Kevlo911's Avatar
Kevlo for President
How do you know it is overheating of the coolant temp sensor is broken?
Old Jun 25, 2010 | 07:55 AM
scmaxima's Avatar
ok look, its not a blown head gasket, the oil is fine! its not the fans too because they both work as soon as i turn the ac on.
The ects is snapped off but i put it back in place, yes ill change that, and u think all of this can be from a bad tstat?
Old Jun 25, 2010 | 08:40 AM
scmaxima's Avatar
bump..
Old Jun 25, 2010 | 09:15 AM
99zx2's Avatar
if it's stuck closed, then yes. it doesn't allow the coolant to cool your engine.
Old Jun 25, 2010 | 10:24 AM
BlackMax1997's Avatar
When did the overheating start? If a month passed after the wp and tstat were replaced, then it's not likely that the tstat was installed in reverse or that there's a problem with it. If the ECTS got snapped right before the issue started, then that's likely the problem. Are you sure you purged all the air out of the system after you replaced the other parts? You could have an air pocket that has moved to a position that is causing the issue.
Old Jun 25, 2010 | 10:38 AM
99zx2's Avatar
^^true that. bleed the system when the car is cold by opening the radiator cap and looking for bubbles getting to the top of the filler neck. Wait till the level starts rising. Once that's done, just put the cap back on.
Old Jun 25, 2010 | 11:02 AM
If you do this, it would probably be a good idea to elevate the front of the car to allow the air to move towards the front of the system. Let it run with the radiator cap off until the level rises. Also, have you replaced the radiator cap? That's something that is often overlooked, but needs to be done as well.
Old Jun 25, 2010 | 11:27 AM
scmaxima's Avatar
hmm funny thing now =/ i just checked it again and the problem is still there... i found that the engine burned some oil tho so i filled it up. BUT the radiator keeps drinking the antifreeze real fast! i just let it cool down to find that AGAIN the reservoir is empty, and the radiator is half empty 0.o the car overheats from an entire night of being shut off in bout 4 minutes after turning it on
whats the problem there guys
Old Jun 25, 2010 | 11:40 AM
99zx2's Avatar
find where your coolant is going! might be your water pump.
also check your oil for coolant contamination.
Old Jun 25, 2010 | 11:50 AM
OP, have you tried pulling your tstat out and running the car temporarily without it? I know the tstat is only like 2 mos. old, but it's possible that it could have had some sort of a defect. Also, have you flushed your radiator? You may need to do that and check the flow out the bottom to see if its adequate. You could have trash buildup in the bottom of your radiator that is causing an inadequate flow problem.
Old Jun 25, 2010 | 11:51 AM
njmaxseltd's Avatar
Blown head gasket from the combustion chamber to the cooling system. Whats pushing the coolant out is combustion chamber gasses. Get a mechanic with a sniffer to verify that you have exhaust gases in your cooling system.
Old Jun 25, 2010 | 11:54 AM
On a more serious note, IF it is a head gasket, the coolant could be leaking into an exhaust port and burning off. You would be able to tell if your car is putting a lot of steam out of the exhaust and if your cooling system pressures up really quickly. After I've had a chance to think about the symptoms your car is having, a blown head gasket is not so far fetched...
Old Jun 25, 2010 | 11:56 AM
FallenOne's Avatar
Well.. First off be sure the hoses have pressure and that your exhaust isn't whitefrom burning coolant.
Have you made sure your radiator isn't cracked? Mine was and ate coolant like mad... Also it ended up ghosting a erg and knock sensor code as well as an O2 due to it slightly overheating.
Old Jun 25, 2010 | 11:58 AM
scmaxima's Avatar
hmm thing is.. the coolant just dissapears.... i dont think its going in the engine cause the oil is perfectly yellow/brown. but idk =/ the ECTS is completely broken, and hmm radiator gets realllllly hot, even the pipes. in literally no time so yea.. im really clueless guys and i cant move the car because i can risk burning the engine even just to go to the mechanic
Old Jun 25, 2010 | 12:00 PM
scmaxima's Avatar
well i doubt its cracked because i dont see any coolant on the floor at all.. and the reason i think it has pressure is that when the car is warm, i touch the pipe its very hard and hot so im assuming it has pressure. oh and the rad cap is new 2, so its not loosing pressure
Old Jun 25, 2010 | 12:02 PM
If you have a blown head gasket, coolant doesn't automatically go into your oil. If the gasket is blown at an exhaust port location, the coolant will vaporize and go out the exhaust, and you will have exhaust gases in your coolant system.
Old Jun 25, 2010 | 12:13 PM
FallenOne's Avatar
I didn't see coolant either. It was a pressure leak, a hairline crack. Was a pain in my ***. Basically.... I had to warm the car up, throw a zip tie on the tb to hold a higher rpm and look for the crack... Figures it was right up top. Fragile brittle pieces of crap.
Old Jun 25, 2010 | 12:35 PM
VQphantom's Avatar
i Had the same problem its a blown headgasket man trust me its very fustrating
Old Jun 25, 2010 | 02:00 PM
scmaxima's Avatar
is it for sure???
how can i fix it temporarily at least till i sell the car? or there isnt any way =/
Old Jun 25, 2010 | 02:29 PM
98Maximo's Avatar
is it for sure???
so basically how can you cover it up so the next buyer gets screwed into buying it?
Old Jun 25, 2010 | 04:12 PM
2000_MAXIMA_KING's Avatar
is it for sure???
Damn thats durty homie
Old Jun 25, 2010 | 05:00 PM
EsQueue's Avatar
is it for sure???
I scrapped a VW passat due to slight rod knock. When my mechanic recommended that I put a very thick oil and treatment to hide the noise and sell the vehicle, I dropped him. Donated the car instead.
I fu*king hate thieves.
Old Jun 25, 2010 | 07:00 PM
SiathLinux's Avatar
+1 here...
Either fix it right, or sell it AS IS - telling them that it needs a head gasket.
Old Jun 25, 2010 | 07:44 PM
Br0nz's Avatar
is it for sure???
+B this guy
Old Jun 25, 2010 | 08:16 PM
is it for sure???
Well, if the coolant "disappears" really quickly and it's not dripping/leaking......it's pretty obvious. It's a blown headgasket. When it's cool out, look at your exhaust coming out the pipe. Is it white?
Since the car gets hot really fast, it sounds like you didn't install the thermostat correctly...
No, there's no temp fix for this. And shame on you for mentioning passing the buck to the next buyer.
Old Jun 26, 2010 | 11:59 AM
scmaxima's Avatar
ok so now i figured... im gonna fix it and sell it. or just put it up AS IS with the problems listed...
but still, i dont know if its really a headgasket, i dont smell anything wrong in the exhaust except the rich smell of gas that ive been smelling since day one, and thats why i get like 11 MPG lol
could it be anything else other than the tstat or ECTS?
Old Jun 28, 2010 | 08:58 AM
cashoit's Avatar
YUP!!
Old Jun 28, 2010 | 09:40 AM
urmab's Avatar
You get 11 MPG because you live in NYC, Traffic here is horrible, if you haven't changed your tstat maybe you should do so.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
97_GXE
20
Sep 17, 2015 08:12 PM
Alberto10mg
Aug 25, 2015 12:54 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
