power steering leak
Old Jul 11, 2010 | 04:02 PM
Maximeltman's Avatar
power steering leak
That ps U-shaped hose in the radiator is leaking, and it's getting all over the lower radiator/engine support beam...is this **** corrosive? I read mixed reviews. this is the same ps fluid I've had since buying the car back in '03.
Old Jul 11, 2010 | 04:45 PM
Trini Boom's Avatar
Get that U-shaped line replaced since its leaking. Once you change it, get a hose and wash it off. I am pretty sure your condenser can use the washing off with the bugs that's on it anyways.
Old Jul 11, 2010 | 04:46 PM
Kevlo911's Avatar
Kevlo for President
PS fluid in our cars is ATF. And replace the hose and clamps, it should stop the leak.
Also where is this hose?(pic) I thought our rads only had the tranny cooler in it?
Old Jul 11, 2010 | 04:56 PM
Trini Boom's Avatar
He is probably referring to the aluminum piece that goes out to the front of the condenser. Other than that, there is no other hose going out there for PS fluid.
Old Jul 12, 2010 | 09:22 AM
asand1's Avatar
Is it the tube, or a shltty connection where the hoses clamp on? I would go buy a small cheap tranny cooler to replace that stupid stock "cooler".
Old Jul 12, 2010 | 10:14 AM
cashoit's Avatar
Its not corrosive. Mine has been leakin for months. Replaced the clamps, still leaking. Ima try replacing the hoses with new ones. If that dont work i might replace the entire line or i may jus bypass the entire cooling line at the reservoir. I PM'd a fellow member who has done this, 3 yrs no issues.
Old Jul 16, 2010 | 01:55 PM
Thx evry1...
Kevlo, the hose is located in front of the radiator, near the passenger side.
Old Jul 18, 2010 | 08:52 AM
Now I hear a loud wine whenever I turn the wheel...any ideas what this is now? LOL hope nothing serious I think it's related to the PS.
Old Jul 18, 2010 | 09:22 AM
asand1's Avatar
Air in the syatem/low fluid. You have been adding fluid, right?
Old Jul 18, 2010 | 03:11 PM
Thanks asand1.
I just changed the rubber hose with a new one, tightened the clamps all the way, and it still leaks! It's crazy hot outside and working in the heat is taxing. I am starting to wonder if the leak is coming from the metal hose like if it has a crack or something..if it is the metal hose then I'd have to just bypass the stupid cooler attempt that nissan tried making. If it does cool the fluid it could only be 2 degrees at most.
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
2kmaximel
Sep 10, 2015 08:13 AM
ag90fox
Sep 9, 2015 12:22 PM
SusieQQ
Sep 9, 2015 12:14 PM
