Tricking Airbag system with resistor?
Hey guys,
I got some seats from a 96 i30 which does not have seat airbags, where as my car did have them, so my airbag light is flashing on my dash
I would really love to keep these seats because my drivers side one was done! yet I don't want to compromise safety for a rip in my seat lol
Has anyone tricked the system by using a resistor before? if so which resistor did you use?
Thanks!
Thanks!
I suppose that it is possible. As for which value, why don't you measure the resistance of the airbag. DO THIS AT YOUR OWN RISK. Maybe you could run the self diagnostic and confirm this is the problem (although I would think it almost certainly is). If you choose to go a head with this, read the RS section of the FSM first.
Or are you actually saying you don't wanna sacrifice 4 airbags, but 1 is fine.
The seat cushion might be swappable.... then you wouldn't sacrifice any airbags at all.
well I meant i'd rather compromise the seat airbags then all of them
since none of them are working right now because the seat airbag is unplugged
I just don't think the seat airbag is all that much important considering it was an option on these maxima's and not standard
Ya, i guess i could dismantle the seats, but that would be quite a bit more work then adding a resistor to the harness I believe
I'll see what happens, thanks for the suggestions guys
im thinking ill get a variable resistor and then test it with an ohm meter, and then buy the right resistor
And is repairable too.
Why in the world would you swap and downgrade a safety feature?
Makes no sense at all.
Go to any auto interior shop, Goolge will help you find one in your area.
Have your seat fixed and maintain the safety feature your car came with.
Had my Explorere driver seat recoved, OE peforated leather was about $300 bucks. Totally worth the $$ spent, and in your case with the SRS Side Impact Air Bags, it's a no brainer.
FWIW. I could not find any information in the FSM, but it is possible that even if an airbag is missing and the air bag light is flashing the rest of the system may function normally as long as it is in operable condition. Although you won't be able to tell if the rest of the system is operable because the light is always flashing. I agree with the others that it is best to have a functioning side airbag if at all possible.
You may want to try a google search to find your answer..
http://www.google.com/#hl=en&source=...1b00b7cb80fe03
http://forums.vwvortex.com/showthread.php?3674350
http://forums.vwvortex.com/showthread.php?1954862
The man would rather have a resistor than swap out a seat cushion... we're wasting our breath.
hmm interesting, I was told differantly...well thats why im here! for answers
thanks
thanks though..
The control module you now have under the console has a place for two wiring connectors, one for the front bags & one for the side. Just get an air bag module from a car without the side air bag option. It will only have one outlet for a connector. The other wire connector that controls the seat air bags will just hang loose under your console. If you install this and then reconnect your battery, your system will be reset and no light should appear.
About a year later though I found some black air bag seats, so I reinstalled the original module. It's all good.
knight_yyz
11-01-2015 01:34 PM
