clutch issue
Old Jul 20, 2010 | 07:03 PM
Jdmfosho's Avatar
clutch issue
I recently just changed the clutch in my 97 maxima and it engages fine. But if i go past like 3k rpms it starts slipping. It doesnt slip bad but i can definatly feel it. Did i do something wrong? what could be causing this?
Old Jul 20, 2010 | 10:10 PM
Snypa's Avatar
how many miles have u gone since installation.? Did you break in the clutch properly.?
Old Jul 21, 2010 | 08:06 AM
cashoit's Avatar
new clutch shdnt be slippin at all. How was condition of flywheel? Where u get clutch from?
Old Jul 21, 2010 | 08:27 AM
bamboomerang's Avatar
sounds like some greasy fingers got on it - what brand clutchkit?
Old Jul 21, 2010 | 09:32 AM
Jdmfosho's Avatar
like 10 and yea
it was heat scored and then i took it to get resurfaced and the guy said he had to do it by hand cause the machine was messed up and i got it from Napa
Old Jul 21, 2010 | 09:39 AM
10 miles isn't properly broken in
Old Jul 21, 2010 | 09:43 AM
Jdmfosho's Avatar
haha sorry i meant so far ive been following the break in procedure.
Old Jul 21, 2010 | 06:43 PM
MAXIMA_STYLE's Avatar
is the clutch aligned properly? did everything get bolted down as it should have been? what brand clutch is it and how hard do you drive? i know no matter how hard you drive a new clutch it shouldnt slip btu you need to take quality into consideration...
Old Jul 21, 2010 | 07:09 PM
speedofsalt32's Avatar
did you replace the pressure plate, fly wheel? Did you check their condition?,Is your upper oil pan gasket leaking ? oily clutch
Old Jul 22, 2010 | 10:41 AM
Jdmfosho's Avatar
Yes i aligned it properly and i torqued it down to specs. Not sure i got it from napa as an oem replacement. i dont drive hard but when i was testing it out as full throttle it began to slip like at about 3k rpm
Pressure plate yes flywheel resurfaced. and no
Old Jul 24, 2010 | 03:40 PM
Jdmfosho's Avatar
bump
Old Jul 24, 2010 | 06:17 PM
so its oem not performance then....thats your problem LOL...nah im just kidding, id say check your plugs anything that causes hesitation...it could be something else went bad and you just got bad timing....coinsciedence i guess...check all your parts you removed in the process
Old Jul 24, 2010 | 10:08 PM
asand1's Avatar
Originally Posted by Jdmfosho
like 10 and yea
If said "Dude" did it by hand, then its not "proper" and you have a sh!tty flywheel surface.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
