need help vaccum leak or coils?
Old Jul 29, 2010 | 03:16 AM
se96's Avatar
My max started off with the rpm getting stuck at around 1700 at idle. I would have to
Shut off the car and start it again then it would be fine and at random maybe 2 mins or
Maybe 3 days later it would do it again. Now it idles rough like 65 percent of the time
And still gets stuck around 1700 occasionally sometimes ill tap the gas and turn my wheel
And it will drop back to atound 700 then it will bounce around from 600 to 500 rpm and idle violently I hope I explained this good lol.
To me it seems like a vaccum but I can't find it
Thanks in advance
Old Jul 29, 2010 | 09:58 AM
maxed_out_99's Avatar
if you could make a video it would help alot. now... does it sound like a v8 with a cam? that is the sound of a vacuum leak im not to sure what a bad coil sounds like, i never had to replace one, but im sure if it was a coil the idle would always be low and you would have a hard start. the best place to start is to get a vacuum gage slam it on the manifold and at idle it should be anywhere from 14hg to 20hg. vacuum leaks are loud. unless you have a ridiculously loud intake or a s/c you could hear it. but as of right now these are just suggestions i cant really diagnose it until i hear it. any codes?
Old Jul 29, 2010 | 11:07 AM
cashoit's Avatar
Thanks in advance
Have u tried cleaning TB & MAF per the how-tos. Clean TB sounds like the fix to me.
Old Jul 29, 2010 | 11:15 AM
asand1's Avatar
+1, also could be intermittant IAC. Vacuum leaks will generally NOT be intermittant, motor will always idle high. Also check TPS.
Old Jul 29, 2010 | 04:57 PM
asand1's Avatar
The coils aren't gonna make you idle high either.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
