No A/c
Old Jul 29, 2010 | 05:08 PM
_buddha's Avatar
No A/c
Ok guy so the other day i replaced my alternator and while doing so this wierd wire disconnected that connects to the a/c compressor. so i basically just re-connected it, its looks kinda like a fuse connected to a wire and the input is like just a hole. And now my car is running but now i dont get cold air! im not sure if that was the problem or not but now...i get air but not cold air...and its hot as a mother right now and im dying. lol help out, i'll try to get a pic of this wire later..
Old Jul 29, 2010 | 05:24 PM
Br0nz's Avatar
Fusable link? I'm not sure where you are I look forward to the pic
Old Jul 29, 2010 | 05:29 PM
maxfever1987's Avatar
check inside the engine bay theres a fuse for it there as well, and while changing the alt. did you pull out the ac comp, if so did you disconnect the feed lines that go onto it cuz if you did than there goes your freon,
another thing when you put the ac on do you hear the ac comp. click on?
Old Jul 29, 2010 | 06:24 PM
_buddha's Avatar
So I just plugged the connector back in but the connection is still kind of loose, but for now the a/c is back! So what the hell is this wire? Should it be all good now ?
Old Jul 29, 2010 | 07:12 PM
Trini Boom's Avatar
Is that the wire that you plugged back into the compressor?? If not, where is that wire coming from? If it is thw wire connected to the compressor, what happened to the protective covering??
Old Jul 29, 2010 | 07:23 PM
mateusz1945's Avatar
that could be wire that turn on clutch in a/c compressor, yep it suppose to be to plugged into compressor. i would check voltage on the connector , suppouse to be like 12,5 only when u turn on ac, if there is voltage fuses are OK, and u have to looking for problem in compressor side connector
Old Jul 29, 2010 | 07:50 PM
99zx2's Avatar
^^what he said. fix that connector properly. your voltage might fluctuating because of the broken connector, thus not allowing it to work 100% of the time.
Old Jul 29, 2010 | 08:25 PM
ArialChi's Avatar
i agree cheak the connector
Old Jul 29, 2010 | 09:54 PM
_buddha's Avatar
Yah that connector turns on the clutch on the a/c compressor. When it disconnected during installation of alternator I reconnected it ****ty and well it mustve got loose while driving and d/c again. Now it's all good, I'll connect it properly and tape that **** up so it doesn't happen again. Thanks guys
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
