Manual Climate Control issue
Old Aug 4, 2010 | 10:31 AM
midnight0045's Avatar
I'm having a problem with my manual climate control device in my car.
I push the button that directs the blower 100% to the feet and the air ends up coming out of the defroster fans holes and no air comes out by the feet. If I push the defroster + feet option again the air only comes from the defroster area and none from the floor.
What is the cause of this problem? Do I need to look for a new one of these...?
Old Aug 4, 2010 | 10:38 AM
kiecas17's Avatar
Maybe a possibility you have a new friend living in your car?
Old Aug 4, 2010 | 12:12 PM
beegeezy's Avatar
Haha...put some cheese out for him!
Old Aug 4, 2010 | 12:14 PM
anyone with helpful advice?
Old Aug 4, 2010 | 12:55 PM
beegeezy's Avatar
We were trying to be helpful. You could have a critter blocking the blend door from moving. Whatever the problem is, it's with the blend door.
Old Aug 4, 2010 | 01:14 PM
well there isn't an animal in my car. how accessible is the blend door? behind the radio cluster?
Old Aug 4, 2010 | 01:37 PM
beegeezy's Avatar
IIRC it's under/behind the glovebox. It's not the blend door btw, that's for the temperature change. I meant the mode door. You can move the mode door lever yourself to see if it is blocked. Also, it could be the mode door motor is failing. Don't be so sure there isn't a mouse in there...
Old Aug 4, 2010 | 01:42 PM
beegeezy's Avatar
My bad...it is behind the radio. http://www.nicoclub.com/FSM/maxima/1998/HA.pdf
Page HA-38 shows the location and the lever I mentioned.
Old Aug 4, 2010 | 01:59 PM
somewhere here?
Old Aug 4, 2010 | 03:13 PM
BiRd DaWgY's Avatar
Thanks for the help mine was doing the same thing
Old Aug 4, 2010 | 08:51 PM
beegeezy's Avatar
somewhere here?
Yes, the levers attached to the mode door motor are what you want to check for movement when you press the different vent modes. You can check the wiring at the motor plug too if you think it's a defective motor.
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima30
Sep 7, 2015 06:13 PM
