Relocating KS?
Old Aug 5, 2010 | 03:32 PM
95Maxed's Avatar
Relocating KS?
Is it possible to relocate my KS to be on top of the manifold, there are two holes for bolts at the top right, im thinking of moving it there.
Reason? Because the ratchet my friend used to try and remove my KS got stuck...........................
Old Aug 5, 2010 | 04:48 PM
Kevlo911's Avatar
Kevlo for President
I wouldn't recommend it. But you can move it if you want.
Old Aug 5, 2010 | 06:24 PM
95Maxed's Avatar
Why wouldnt you recommend it? As my car sits now, the sensor it broken, and I just cannot get the bolt off, and im not paying 600 for a mechanic to remove one bolt.
It seems as though it would work?
Old Aug 5, 2010 | 06:37 PM
Kevlo911's Avatar
Kevlo for President
well the rubber gasket on the im might not let the sensor read anything so you will always be at full timing. If you really have to relocate it, find a bolt on the block.
people that do the bypass mod will say there is no problem moving the sensor but you run the risk of knocking and the ecu not doing anything about it and thus harming the engine
Old Aug 5, 2010 | 06:43 PM
95Maxed's Avatar
Bypass mod? What do you mean? Like delete it?
Old Aug 5, 2010 | 06:44 PM
Kevlo911's Avatar
Kevlo for President
Yeah they put a resistor to fool the ecu into thinking there is a ks there.
470k ohm
Old Aug 5, 2010 | 06:49 PM
95Maxed's Avatar
470k ohm
Hmmm, thats kinda cool. I wouldnt go that route though. I'll look for somewhere on the block to place it, if anyone knows, please chime in
Edit: If I do go the resistor way, all I need to do is run 91+ fuel to avoid knocking and listen for any knocking?
Old Aug 6, 2010 | 12:32 AM
96i30azn's Avatar
If you use a KS that's mounted badly, it's the same as the resistor. Here it is if you're interested:
Old Aug 6, 2010 | 05:51 AM
95Maxed's Avatar
Ok, so it WOULD work, but those who do it just need to watch out for engine knock? Thanks for the write up by the way
Old Aug 6, 2010 | 05:57 AM
cashoit's Avatar
Honestly when u look at the normal location for the KS it is in an optimal central symetrical location to "sense" all six cylinders.
The KS on the side of the engine like that is NOT optimal. But it IS a quick fix lol
Old Aug 6, 2010 | 06:38 AM
95Maxed's Avatar
As I said before, ive got a, ummm... wrench... stuck on my current KS and its broken. So I need to move it.
This is all under the assumption that firestone didnt remove my intake to change my power steering pump and replace the ks (and retrieve my wrench) already
Old Aug 6, 2010 | 10:13 AM
95Maxed's Avatar
Double post, can someone link a tutorial/write up on the resistor mod? I cant seem to find one, and that may be my better option.
Old Aug 6, 2010 | 10:45 AM
cashoit's Avatar
you cant retrieve the wrench out of the IM cavity?
Jus have someone with lil hands get it.
Old Aug 6, 2010 | 10:48 AM
Kevlo911's Avatar
Kevlo for President
its in the stickies
Old Aug 6, 2010 | 02:54 PM
DennisMik's Avatar
If you have a wrench stuck in there, you really should get it out. The wrench is probably on an angle to the bolt head and wedged on. Figure out which way the wrench is tilted and straighten it (probably with a hammer) to get it off. Then you can loosen the nut with a short box wrench.
Old Aug 6, 2010 | 03:33 PM
95Maxed's Avatar
No no, its on the bolt, and stuck b/c its pinned against the manifold
its in the stickies
Found one, thanks
The wrench is doing no harm, its not in the way of anything. Its got a swivel head but the fuel line is in the way and i cant swivel it down enough to get it out. My friends an idiot and i cant believe he got it stuck
Old Aug 7, 2010 | 05:30 AM
speedofsalt32's Avatar
You're the man good idea Had a suby with valve noise, KS kept throwing a code. We bolted in to the firewall, got it to pass emissions
470k ohm
Old Aug 7, 2010 | 03:02 PM
DennisMik's Avatar
OK, what I think has happened is that the bolt has been partially screwed out but it is not out of the threaded hole because the socket wrench is in the way. So all you need to do is screw the bolt back into place, but don't tighten it and take the socket wrench off. Then you can take the bolt out by hand or with a box or flat wrench.
Old Aug 7, 2010 | 03:53 PM
95Maxed's Avatar
Nope, not it, we didnt get the bolt to budge.
Old Aug 7, 2010 | 09:05 PM
DennisMik's Avatar
I go back to my first post then. You'll have to use some BS&I (brute strength an ignorance) to get it off.
Old Aug 7, 2010 | 09:28 PM
95Maxed's Avatar
Tried lol, fuel line is in the way and im not messing with that lol. Guess my engine just has a friend lol
Old Aug 7, 2010 | 09:37 PM
nelledge's Avatar
"I'm just sayin'..."
I don't believe I would leave that in there. It's not stock and really has no performance gains. eh... take it off. Have you tried the two p's? Persistence and patience.
Old Aug 7, 2010 | 10:42 PM
95Maxed's Avatar
I nearly got drunk I had so much of it
Old Aug 8, 2010 | 06:16 PM
Trini Boom's Avatar
:metalmax:
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Chebosto
Jul 19, 2002 11:29 AM
multiplexor
Jun 22, 2002 06:22 AM
tom_98se
22
Sep 15, 2001 11:39 PM
