Help - Pulley Problem - See Pic.
Old Aug 29, 2010 | 11:08 AM
99fivespd's Avatar
My power steering belt broke yesterday and my alt belt was almost off I am trying to change my belts , however, it seems like my main accessory pulley is broken because it is riding on top of the crankshaft sensor. Can anyone tell from this picture?
Old Aug 29, 2010 | 11:29 AM
asand1's Avatar
You need a new crank pulley/harmonic damper. that's what killed your belt.the rubber bond has broken.
Old Aug 29, 2010 | 02:15 PM
Trini Boom's Avatar
+1. Another crank pulley. You are not the only one..seems like this is starting to become a problem now for these cars...
Old Aug 29, 2010 | 05:13 PM
99fivespd's Avatar
Got 19MM bolt out - pulley still stuck.
I was able to remove the 19mm bolt w/ a breaker bar and blip starting it, however, now the pulley is still not budging. Do I need a pulley puller or should I try prying it off?
Old Aug 29, 2010 | 07:25 PM
DennisMik's Avatar
You need to use a puller. Don't try to pry it off, you'll probably break something.
Old Aug 29, 2010 | 08:11 PM
99greddymax's Avatar
when i installed my upd, i didnt need a puller.. i just tapped it with a hammer, and came off by hand.
Old Aug 29, 2010 | 08:56 PM
Trini Boom's Avatar
Get a puller for it..which is quicker than trying to soak it in some penetrating fluid and trying to pull it off. Do it once and do it right!
Old Aug 30, 2010 | 03:16 AM
antti's Avatar
Do not use a hammer when crankshaft is involved..
Old Aug 30, 2010 | 04:33 AM
myblzurchn's Avatar
Well you may as well just go out and get an underdriven pulley from Unorthadox racing, a little pricey but I'd say worth it since you already have to replace it. JMO.
Old Aug 30, 2010 | 05:10 AM
plugeye's Avatar
what for? i found a good used one on here for under $40 shipped. or you can just have the pulleys welded back together
Old Aug 30, 2010 | 06:55 AM
well i did, and nothing happend.. and notice when i said "tapped"!
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
