GXE wheels aren't that heavy after all...
Old Dec 15, 2001 | 12:37 PM
Vyrus's Avatar
Well I had nothing better to do today, so I thought I would find out the weight of my original 1996 Maxima GXE "steelies". I massed the tire/wheel combo and subtracted the weight of a tire (same size) I had in my garage. All the tires are the original 205/65R15 size. Here's what I got:
Wheel/tire combo: 41 lbs.
Tire alone: 23 lbs.
Est. Wheel weight: 18 lbs!
I always thought the stock steel wheels were way heavier than that - and no my scale is not broken its almost brand new and perfectly calibrated. Anyways, just thought I'd share my findings.
-Cyrus
Old Dec 15, 2001 | 12:46 PM
Sprint's Avatar
your scale has a Virus .. or your fat gf adjusted it
Old Dec 15, 2001 | 12:47 PM
Sonic's Avatar
Re: GXE wheels aren't that heavy after all...
Tire alone: 23 lbs.
-Cyrus
Cool.
Old Dec 15, 2001 | 12:51 PM
Vyrus's Avatar
Sprint...
1. True, I could be spreading .
2. No g/f , maybe yours (or was that your mom)? .
But seriously, I recalibrated it before I used it. Does that seem even remotely realistic? A tire weighting 4 lbs. more than the wheel?
-Cyrus
Old Dec 15, 2001 | 05:14 PM
Solo950's Avatar
I took off my factory wheels the other day to put on a set of snow tires (on different steel rims). I weighed the original wheels with the tires on them also. I got very close to the 41 pounds that you got, so I think your numbers seem perfectly reasonable.
Old Dec 15, 2001 | 05:17 PM
Mad Dhan's Avatar
Tire alone: 23 lbs.
-Cyrus
Do you mean the hubcap/steel wheels?
Old Dec 15, 2001 | 09:11 PM
BRIGBOY's Avatar
Seems close...
..they spin much more freely than my 18's.
Old Dec 15, 2001 | 09:36 PM
ptatohed's Avatar
Licensed to Spell
Tire alone: 23 lbs.
-Cyrus
Thanks for letting us know Vyrus. I have always heard that the stock GXE 15" steel wheels/hubcaps were light. You got me curious so I went out to the garage and weighed my stock '96 GLE 15"s wheels/tires (The pollished finish ones with the cheesey flower/snow flake design). I don't beleive they are stock tires but they are 205-65 which is stock size (and they are made by General if that helps any). I got 37/38 pounds. Not too shabby I guess. I don't know what just the rim weighs but using the same logic as you, I guess around 14/15 lb. )
I'm stoked because I thought the GXE wheels were lighter so I was actually looking into getting 2 or 4 of them (for those friday nights). Now I know to just keep mine. Thanks again.
P.s. I know it's not much but was your weight with or without the hubcap?
Old Dec 16, 2001 | 08:21 AM
Synki's Avatar
Just remember, tires are like rims, they all have different weights too.
Old Dec 16, 2001 | 10:01 AM
NYCe MaXiMa's Avatar
I always thought that way.... First of all the smaller the tire, the lighter it is (obviously) then 15" rims are all generally lighter then most aftermarket 17's... A stock tire/rim combo would probably weigh about the same as a light weight 17-18 lb 17 inch rim w/ tire.
I had lightweight 16 X 7" 15.5 lbs rims w/ 24 lb tires. The combo was similar weight to stock alloys, ofcourse just a bit lighter, but that is going only 1 size up. All tires are heavier as you go to a bigger size.
Old Dec 16, 2001 | 10:55 AM
Weasel's Avatar
Another bit of info, the 97-99 SE wheels feel significantly lighter than the GXE steel wheels. I spin my tires much easier since I put the SE wheels on.
Old Dec 16, 2001 | 12:17 PM
mattC's Avatar
you need some better tires
Old Dec 16, 2001 | 12:51 PM
Weasel's Avatar
Actually I went from bald (literally, almost slicks) Firestone SH30s to almost new Yokohama A540 VRs. I was surprised by it also, but my tires do spin a lot easier. Maybe it's just my lead foot.
Old Dec 17, 2001 | 03:06 PM
Vyrus's Avatar
Well...
The weight was without hubcaps - but they are almost nothing (under .1 lbs) and will not make a difference. Anyways they were alot lighter than I presumed, so maybe this will scoot wheels down on the "mod list" for one or two of you...nah, not a chance .
-Cyrus
matts95max
Apr 23, 2025 10:44 AM
markevans999
Oct 25, 2015 08:27 AM
rnb754
Sep 14, 2015 11:39 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Violator
Sep 9, 2015 10:14 AM
