Little Modifcation i did on my '95 max with the front lights
Old Dec 15, 2001 | 03:50 PM
romeonyc's Avatar
I always wondered why nissan never had both of the front corner and front blinker lights be on all the time, Instead they only have the corner turn lights on all the time and the front lights turns on only when you signal...Well this sorta ****ed me off, i wanted to be different, so what i did i hooked up an extra light bulb and inserted into the front light signal light, So now my front turn signal stays on and so does the corner light, looks soo much nicer now that i got all clear lenses around and the whol side is lit up
Old Dec 15, 2001 | 05:45 PM
Justin95SE's Avatar
can you elaborate
i like that idea, but i am a little unclear about what you did. pics would be cool
Old Dec 15, 2001 | 07:19 PM
dko's Avatar
dko
duck and cover
Re: Little Modifcation i did on my '95 max with the front lights
you're not the first, but there is a better way. you can use a two-way light socket and splice some wires. there's an FAQ around somewhere.
what I would like is to have the corner pieces of the headlights to be bright all the time (like when you use the turn signals).
Old Dec 15, 2001 | 07:36 PM
Justin95SE's Avatar
how to do what dbk wants
heres how i did it. There are three wires, two colored wires and a black one. i switched the two colored wires. then its always bright, the brighter filament is burning. how most other members of the org have done is sand down the 2 little nubs on the bottom of the bulb. same thing. do a search, that should turn up a lot.
Old Dec 15, 2001 | 08:47 PM
BRIGBOY's Avatar
.dko...get a double filament and shave the nub, search will show the bright light, whallla equal brightness from all 4 headlights(corners and lamps).
romeonyc - can u signal a turn? search away
Old Dec 16, 2001 | 01:32 AM
romeonyc's Avatar
Re: ...........
Yes i can signal a turn, it signals at the same time, but also the 2nd light bulb stays on all the time, its phat, I was going to ask about that corner light being brigther, how the hell do i do that?? what do u mean by "Double filament and the shave the nub" please explain in further details cause iam willing to do it
Old Dec 16, 2001 | 01:34 AM
romeonyc's Avatar
Re: Re: ...........
I have another questions, where the hell do i get those COOL white lights for the corner, cause now they look like **** white, lol
Old Dec 16, 2001 | 05:58 AM
Sonic's Avatar
Re: ...........
That only works in the '97s, not the '95s. BTW, ALL the things that you all have suggested have already been posted in the 'How To' section of www.maximadriver.com
Old Dec 16, 2001 | 10:32 AM
BRIGBOY's Avatar
Re: Re: ...........
Whatchu talkin bout willis....I have a 95.
My corner(parking)lamps are equally as bright as my hyperwhite halogen bulbs. I think its an 1157 and you shave off 1 nub so its like the high beams are always on on the corners only. Or is it an 1156? Its been so long since ones burnt out(which can be the only problem).
Old Dec 16, 2001 | 11:47 PM
romeonyc's Avatar
Re: Re: Re: ...........
If i get one of those Cool Ultra white bulbs, do i need to shave of 1 nub to match up with the headlights, or that hypewhite will do just without shaving off?
Old Dec 17, 2001 | 07:37 AM
Sonic's Avatar
If you shave off a nib with a '95-'96 the light will go off when the turn signal is not on. Trust me.
Old Dec 17, 2001 | 07:42 AM
multiplexor's Avatar
i shaved off the nib on my corner lights and inserted them reverese...
they always stayed on, even with the turn signal on.
Looks great
/me=96 max
Old Dec 17, 2001 | 09:10 AM
breaux124's Avatar
It's been done, but a little differently
http://csc.smsu.edu/~jack/max/blinkermod.html
Old Dec 18, 2001 | 01:30 PM
bsr1031's Avatar
I have a 95 SE. Even with hyperwhite bulbs in the corner it didn't match up well to my headlights. So I did the "clip the nub" trick on the corner bulbs (1157) and it looks great. The corners are on all the time at 27w. So they are always bright.
Old Dec 18, 2001 | 03:02 PM
KGBSJU's Avatar
This clip the nub ...... what nub are we talking about here...onw of the two little nubs at the base of the bulb?..
Old Dec 18, 2001 | 04:37 PM
NYCe MaXiMa's Avatar
No
Around the body of the metal part of the bulb at the bottom, there are 2 tiny obtruding nipples. One is on the opposite side of the other one. One is also a little lower (closer to the bottom) then the other one. If you file/shave down the top one (i think it's the top, not 100% positive) you can now put the bulb in backwards, turning it the opposite way, so the lower nipple can now go into the socket of the higher one. The light will be a lot brighter...
Old Dec 18, 2001 | 09:05 PM
RideTheMax's Avatar
Sweet...
I need to try this, I hate those dull corner lights.
Old Dec 18, 2001 | 09:19 PM
KGBSJU's Avatar
Originally posted by NYCe MaXiMa
No
U da best kid....thanx bro.....im new to this game....just got my wheels....dont know much
Roymg
Sep 3, 2018 05:10 AM
vingodine
45
May 21, 2016 12:46 PM
doctorpullit
Aug 20, 2015 05:15 PM
spidgeon
Aug 18, 2015 05:46 AM
papo99
Aug 9, 2015 07:32 AM
