Problem with stepping on the gas DELAY
Old Oct 15, 2010 | 08:02 PM
sspomonag's Avatar
Ok im having a little problem here i really been embarrassed by VW Jetta's.
When i try racing them i step on the gas with the OD off and my car delays to like about 5 seconds and guns it after that when im way behind. What can i do to fix this issue?
I have a 97 I30 with the BBS rims all stock
things i recently changed:
air filter
fuel filter
Oil like 2400 miles ago
spark plugs like 9000 Miles ago
Ohhhhh Yes i forgot im automatic
and i kno theres gotta be a problem going on Thanks
Old Oct 15, 2010 | 08:36 PM
I'm guessing your auto? There's no solving that problem..
Old Oct 15, 2010 | 08:51 PM
sspomonag's Avatar
I kno for a fact that is not normal because before it wasnt that bad
Old Oct 15, 2010 | 08:55 PM
Try cleaning your TB/IACV and tighten up your throttle cable a little and it should help. You'll still have the delay though unless you do a 5spd swap.
Old Oct 15, 2010 | 09:03 PM
sspomonag's Avatar
Thanks man i cant be getting beat by all of these jettas and random trucks so ill go ahead and take this advice maybe some one else can give me more info..
Old Oct 15, 2010 | 09:12 PM
Use this as a guide to clean everything up:
http://forums.maxima.org/4th-generat...g-dummies.html
Old Oct 15, 2010 | 09:19 PM
sspomonag's Avatar
Really helpful Looking forward to waking up in the morning and buying and fixing what i need THanks
Old Oct 15, 2010 | 09:24 PM
You're welcome! Good luck and keep us updated.
Old Oct 15, 2010 | 10:37 PM
eddie982's Avatar
You didn't mention if you have any CEL's? Your issue could be caused by a bad KS or other issues too of course.
Before I changed the knock sensor on my 98 max, i had a similar lag. When i would step on it, the response wasn't there for a couple seconds and it bothered me cuz i knew it should get going right away. Anyhow replacing the KS did the trick, now the power is there as soon as i press the pedal. When i took my old one off, there was no crack, just a little corrosion. It was bad though and causing the retarded timing. Get a new one off ebay, don't buy used.
Old Oct 16, 2010 | 09:23 AM
tfunkadelic's Avatar
I have an auto max and it's got very little lag. Some of it is in how you work the gas pedal - if you work at it a bit, over time you can get a feel for where your foot needs to be to get it to shift and you start doing it preemptively even.
If Jettas are beating up on you there are problems with your car for sure.
Old Oct 16, 2010 | 03:57 PM
Trini Boom's Avatar
Yeah that's for sure even if its an auto. I have an auto and am able to match speeds of the new 5 series..
Old Oct 16, 2010 | 04:39 PM
sspomonag's Avatar
ok well i cleaned the TB and the IACV, car seems to be running better and stronger i havent really tested everything good. But i have no CEL on Ill keep everything updated once i get back later on tonight from a little trip. Thanks
Old Oct 17, 2010 | 12:11 AM
sspomonag's Avatar
Great!!!!! The car is running way better after the clean i was racing a sentra and i got up to 120 and and slowed down i felt bad for the sentra.. Thanks for the info Im happy we could fix this issue i love this community thanks
Old Oct 17, 2010 | 12:35 AM
ef9's Avatar
ef9
So you only cleaned the TB and IACV?
Old Oct 17, 2010 | 12:41 AM
sspomonag's Avatar
Yes those are the only things I cleaned and I just added some fuel injector cleaner, I had also seafoamed it like 2 weeks ago
Old Oct 17, 2010 | 03:14 PM
It's not hard to get to 120 lol But stop racing people.
Old Oct 18, 2010 | 11:43 AM
Phromethius's Avatar
For real! Much better to do it in a controlled setting, drag strip or raceway. Plus you get a neat little ticket at the end proving your awesomeness and that of the 4th gens
Mar 12, 2020 12:06 AM
wingnut2006
Sep 19, 2015 06:13 AM
thenewguyy
Sep 12, 2015 11:12 AM
slowlifer
Sep 8, 2015 05:53 AM
