need help! creaking after replacing inner tie rod!
Old Oct 22, 2010 | 12:51 PM
eFLO's Avatar
so i was sooped to replace the passenger side inner tierod, the boot had been ripped for a while so i went ahead and decided to just replace the the inner too. got everything off put the new one in new boot, done.
now i went to go turn it on theres a horrible creaking, grinding noise from the DRIVER side. not sure if its the tierod on that side, or the strut mount. all i know is that it was not present before i did the work. i drove it a little but the steering feels loose and it will pull really strong to the left.
anyone know what could have gone wrong? desperate for help at this point.
also i notice that ps fluid is leaking from the cap now, does the system have too much pressure in it somehow? idk what is going on.
Old Oct 22, 2010 | 01:39 PM
eFLO's Avatar
ok so i was able to pin point that creaking noise to the strut mount, but is it just a coincidence that it would start making noise right after i worked on the passenger side tie rod?
i mean i did leave the car on jacks overnight since i couldn't finish doing everything yesterday. i don't think that would put any wear on the bearing or anything..
i'm at a loss for why ps fluid is coming up out of the cap though, if theres air in the system all i'd have to do is turn the wheel a few times to bleed it though correct?
Old Oct 22, 2010 | 05:22 PM
Leo_Koneval's Avatar
Bump for you!
There is a strong pull to the left, which sounds like an alignment problem. But I honestly don't know a lot about suspension and it sounds like something went wrong somewhere.
Hopefully someone chimes in.
Old Oct 22, 2010 | 05:33 PM
eFLO's Avatar
i'm pretty sure once i get an alignment tomorrow it will be fine aside from the strut mount. i thought i had botched something but i guess just coincidence. also replaced a busted sway bar link. it should ride muchhh better.
Old Oct 22, 2010 | 06:55 PM
DennisMik's Avatar
If you truly have a problem with the strut mount, that will throw the alignment off. Get that verified one way or the other before you waste your money on an alignment.
Old Oct 22, 2010 | 07:08 PM
eFLO's Avatar
^ will it really? i mean i get alignment for 25, i just don't wanna drive around with bad alignment until i change the bearing which will probably be mid next week when i have time. i thought unless your lowering, simply swapping out a strut didn't change alignment only when you mess with the adjustment on the tierod..?
PH98I30
29
Feb 10, 2025 12:03 PM
6spd4dsc
Mar 4, 2016 05:19 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
