semi-push button start installation tutorial. (6 bucks lol)
Old Oct 22, 2010 | 03:35 PM
bnrz's Avatar
NOTICE: This is only to bypass a broken ignition switch. Having this button will only be redundant if your switch works.
I personally did it from looking at a diagram so this tutorial will help you complete this project without the difficulties I came across.
I didn't do this because I wanted to be cool; the ignition switch is messed up and I didn't feel like digging into my dash that deep. I actually can't say which is easier, to replace the damned thing or install a push button to by-pass it because there were so many wires to look at.
The reason I say semi-push button is because I have to hold the key in the start position or else the engine won't catch. Not sure why... if anyone knows why, I would love to know.
Anyway... to the meat of my post.
You will need maybe 6 bucks worth of materials. At the most 10. You can get these at your local OSH or Home Depot; choose to your liking. For this case, I found OSH to be cheaper btw.
-a two terminal push button (normally off, this is very very crucial for it to be normally off). it should be the one with the black button.
-a pack of 12-10 AWG wire taps. the pack calls them Tap Splices. they're a banana yellow color. they come in packs of three. you only need two for this project.
-screwdriver
-pliers.
-maybe something to cut some tape. Preferably a samurai sword (katana).
-two feet of 12 gauge wire (2x one foot lengths)
I have pictures of it after I completed the project. I didn't think I was going to share it with anyone.
Step0
Disconnect battery.
Step1
Locate the screws on the driver's side dash. There are two on the two bottom corners and there are clips elsewhere that shouldn't give you any trouble. One of the screws is above the hood latch handle. And the other on the bottom right. Remove panel. There will be a wire connected to the panel, take that off. It will seriously get in you way.
Step2
Locate the wire harness. If it's wrapped with tape, split into the tape to expose two black wires one with a yellow stripe and the other with a white stripe.
Step3
Splice a foot of wire onto the black wire with yellow stripe and the same for the black wire with the white stripe. Shown in picture above.
(to use a wire tap: http://waterforoil.blogspot.com/2008...onnectors.html)
Step4
Now you should have two unconnected wires flying out of your dash.
Connect those to the two terminals on the push button.
Step5
Connect your battery and give it a shot. Turn your key all the way and press the button, when and if the engine catches let go of the key and button. (duh). If it works, yay, from this point on it's not necessary to disconnect the battery but do as you please.
Step6
Where you install the button doesn't matter obviously. I chose to drill a hole on the left side so I can turn the key with my right and press the button with my left.
I put it on the fuse panel cover.
BOOM! put it back together and you got yourself a cheap and easy fix for a broken ignition switch.
Old Oct 22, 2010 | 03:47 PM
eFLO's Avatar
o i like that
Old Oct 22, 2010 | 03:57 PM
99greddymax's Avatar
man get some ring connectors for the switch.. and solder that ish instead of using taps..
Old Oct 22, 2010 | 04:01 PM
bnrz's Avatar
yeah yeah. i have minimal experience with that kinda stuff. this is actually my first electrical experience with my car. i've rebuilt an older engine and didn't really have to play with electric circuits.
don't hate. just a little show-how for people who want to do this.
the only thing i wanted to share is which wires to look for. and what to put on them.
doesn't really matter HOW they put it on.
Old Oct 22, 2010 | 04:39 PM
NSMO240's Avatar
you could also relocate your clutch switch as sort of an anti theft device.
Old Oct 22, 2010 | 04:42 PM
bnrz's Avatar
what does that mean? :O
it's auto if that makes a difference.
Old Oct 23, 2010 | 08:52 PM
DennisMik's Avatar
Step2
The problem might be that you are using the black with yellow stripe wire.
When you turn the key to the start position, the ignition switch sends power down the black with white stripe wire to the starter solenoid. The ignition switch gets the power from a white with purple stripe wire. I don't know what the black/yellow stripe wire is used for. It might not have power in it all the time.
Old Oct 24, 2010 | 11:04 PM
bnrz's Avatar
Well all the button does is connects the b/y with the b/w at my discretion, which apparently engages the starter. So what do you suggest I do with the w/p to make it so I don't have to have the key in the start position?
Old Oct 25, 2010 | 01:39 PM
DennisMik's Avatar
My first three suggestions are to replace the starter switch. It's about $35 at your friendly dealer and not that hard to install. It took me about a half hour to change mine and I had never done that before. I bet you worked harder to put the switch in.
That said, you can try using the white/purple wire on the switch instead of the black/yellow, since that is what the ignition switch uses. I can't guarantee that it will work because the ignition switch has multiple connections inside it and may be doing something with the immobilizer circuit. You could bypass the immobilizer circuit by running a wire from your switch to the small wire on the starter solenoid, but that would probably take at least twice as long as what you have done already.
Old Oct 25, 2010 | 02:19 PM
bnrz's Avatar
yeah... at the time i couldn't really get my hands on a switch (there was too much space in my wallet).
and since my problem was sorta fixed, i didn't really feel like bothering with it anymore.
i should take out the button... but it works nonetheless. :] i probably will take it out soon though.
Old Jun 10, 2013 | 06:57 AM
heart_crafter's Avatar
Ignition Switch (Push Start Button)
Hello all (my first post in maxima.org),
Let's see if someone can help me out
I'm trying to install a push start button. (my ignition switch is dying, I just want to try this and document it.)
Can some one please explain ignition switch wires.
If possible, let me know how should I connect it.
Full Size image
Thank you all!
Old Jun 10, 2013 | 08:04 AM
Fakie J Farkerton's Avatar
The wires you need to tap are listed in the above posts.
As far as your push button starter..I've never seen one like that box..I hope it came with instructions.
Iirc, you will still need your key turned on to get the button to work~so your not really eliminating anything~just a cool factor, or a theft prevention possibility.
As far as the 1st post goes, people are saying he should have tapped the white wire with the purple strip to activate the starter..the ground should be obvious.
It's easier to just replace your switch.
I even have a spare one from a '97.
If your interesed, PM me.
Old Jun 10, 2013 | 09:25 AM
Thanks for the reply.
It did came with instructions but in mostly in Japanese
English Instructions:
Connect the Push Button Connector to the Relay Box
The black wire should be earthed to the metal bodywork of the car or the negative (-) side of the battery
The green wire should be connected to Terminal 15 (ign.) behind the Ignition Switch, with another one connecting Terminal 50 behind the Ignition Switch as well (The power path from ign. to the starting motor)
The red wire should be connected to Terminal 15 (The power path that passes through ign.)
Fix the Relay Box using the double-sided paste and screws provided in the package
And there is no green wire on the relay
bought from
here here
'W/P'(0) is constant 12v.
Which other wire should touch 'W/P' to crank the starter?
I have tried 'B/W'(2)
FYI: when i hit the start button, the blue wires completes the circuit.
Please advise
Old Jun 10, 2013 | 01:39 PM
RA030726's Avatar
I'm nutty for Nissans
I wired one up years ago. I do not remember the wiring, but I used 2 relays and a switch that fits in the cig/acc outlet. I don't like the "ebay" kit. No way would I use t taps.
Old Jun 11, 2013 | 06:00 AM
Ah two relays makes perfect sense since this car got alarm system, and last owner installed something that overrides my clutch switch to start the car.
Connecting B/W and B/Y did not do anything.
I am not really sure what to do So I just fixed the switch temporary and closed it all last night.
To fix the switch. I cut a piece of back side of a Tylenol like wrapper that had some foil and paper and inserted it in the center hole of the switch by the longest wall. Oh also i put some RTV sealant in there before putting the wrapper.
Works good for now till I get a new switch or use the alarm relay some how.
oh FYI my alarm system does not work, when i bought the car remote did not had a back cover. plus i'm not sure if this was a built in alarm system or after market. had problem starting so i removed the alarm relay from the starter that was used to kill start.
Next problem. water under pedals. what keywords should i use to search that ? any suggestions will be appreciated.
I have seen cracked body on the passenger side where water can seep inside. but didn't see anything around driver side. This was done by taking of the cover that is under/front of the windshield. Also im missing the rubber/sealant from there.
Old Jun 11, 2013 | 06:32 AM
Old Jun 11, 2013 | 07:21 AM
Come on it was raining and my battery was dead because i left the switch to on position and went to times square...
and i needed the car today so i had to use what i had in the car at night 12am
thankx!
Old Jun 11, 2013 | 08:19 AM
thankx!
kjlouis
Nov 24, 2018 06:09 AM
JRod28
Feb 4, 2016 11:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
shaunkey1
Aug 18, 2015 10:09 PM
TMartinLVNV
Aug 16, 2015 01:48 PM
