Remote start with factory fob.
Old Nov 3, 2010 | 04:55 AM
Cams's Avatar
My wife wants a remote start for her max for Christmas but I hate the remotes and I know she will too. My question is who makes a remote start that uses the factory fob? I know someone does just dont know who.
Also sorry for another remote start thread I know there alot of them but searching didnt turn up what I was looking for. BTW this car is a 97 auto. Thanks in advance.
Old Nov 3, 2010 | 12:07 PM
beegeezy's Avatar
Lots of alarm manufacturers make remote start systems that can be controlled by the factory remote. I STRONGLY suggest you don't go that route though. You will be limited by the range of the factory remote. There are plenty of remote start systems with nice remotes that are easy to use. Like this one: http://www.sonicelectronix.com/item_...-N+4103V-.html
Or this one if you want an alarm too: http://www.sonicelectronix.com/item_...-N+5102V-.html
Old Nov 3, 2010 | 01:08 PM
Cams's Avatar
Thanks alot. Would you say viper is one of the best?
Old Nov 3, 2010 | 02:03 PM
jholley's Avatar
I installed the commando EZ-2100 about 11 years ago and it's never failed. I programmed it to start after pressing the factory FOB unlock button 3 times.
For more details read this thread:
http://forums.maxima.org/4th-generat...ote-start.html
Old Nov 3, 2010 | 03:48 PM
beegeezy's Avatar
Yeah, the DEI systems (viper, python, clifford, etc) are some of the best ones. If you have a factory alarm you could just get the first system and have it arm/disarm the factory alarm. The two way/paging systems are nice too but the two way remotes can be a pain sometimes.
Old Nov 3, 2010 | 04:57 PM
Trapstars's Avatar
best-buy got the viper kit that you r looking for. I've done it before.
Old Nov 4, 2010 | 06:15 AM
njmaxseltd's Avatar
My remote start is programmed to activate when I press the OE FOB lock button 2x. Almost any remote start system can be programmed to use the factory lock or unlock signals to trigger it.
Old Nov 4, 2010 | 06:35 PM
beegeezy's Avatar
True, but can you start it from over 100 yards away?
Personally, having had remote start on several of my cars I don't like it unless I can start the car from far away...like across an entire parking lot to warm up or cool down the car.
Old Nov 4, 2010 | 08:03 PM
talisman311's Avatar
I literally installed hundreds of remote starts while I was at circuit city... stick with DEI products from an official dealer (otherwise you won't have a warranty, go with the better brand and you'll get another remote and lifetime warranty at a small cost - ie: rattler vs viper). Yes, you can use the factory fob, the installer will hook a negative trigger wire up to the door lock wire...once it's triggered twice it'll start the car (this is usually programmable from 1 to 3 times, as well as run-time, parking light solid or flashing). Make sure you get a competent installer.
Old Nov 5, 2010 | 12:32 PM
beegeezy's Avatar
If you installed DEI alarms (as did I) you should remember that only the alarm brain is covered under the lifetime warranty. IIRC the remotes have a 90 day warranty. The brain almost never fails as it is usually the remotes that fail. (if you get a two-way system) The only real benefit from getting an alarm installed at a authorized dealer is that they will usually troubleshoot their install for free. The alarms themselves rarely ever fail as it's usually a loose wire or faulty factory part that leads to alarm failure. (or the dreaded "the alarm killed my car!" when the car battery dies)
Alarms also have a lot of retail markup. The $100-150 alarms I linked are probably $300-400 installed at a shop. There is plenty of wiring info out there for 4th gens so if a novice takes their time and makes clean connections (solder or quality t-taps) they should have no problem saving a few hundred bucks.
Old Nov 7, 2010 | 03:46 PM
Cams's Avatar
I am not having anybody install it. I hate letting other people work on my car. I am almost always not happy with the results so I do all of my own work now.
I ended up getting a viper unit super cheap last night and just need to find some time to install it.
Thanks for the info guys.
Old Nov 7, 2010 | 11:17 PM
beegeezy's Avatar
Good luck with the install. The only semi-tricky thing on the maxima is the door lock wires in the door and the second starter wire. Check out www.the12volt.com ...lots of good info on there.
Old Oct 26, 2011 | 11:47 AM
hillstead22's Avatar
Did Nissan install any factory remote starters? I know the dealer installs a lot of them, but i'm just wondering if they installed one on my 6th gen max
Old Nov 10, 2011 | 06:12 AM
dennisg's Avatar
I'm also looking for a remote starter kit that will work with the factory remote. Tight budget. Just need to start the car. This is for my daughters car. Some of her classes are early and I figured she could start the car and get warmed up. 04 SL
MR2 T'd
Jul 9, 2021 05:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
