Need Help Please..!!!!!
Old Nov 15, 2010 | 03:47 PM
Rktato05's Avatar
Hey guy i got a 95 maxima and it shaking alot when i accelerate i dont know why its only when i hit the gas to go faster
please help so i know what to fix or check
thanks
Old Nov 15, 2010 | 03:58 PM
beegeezy's Avatar
If it shakes/vibrates only when you accelerate I would check your coils, spark plugs, fuel filter, etc. Is it displaying any MIL codes?
Old Nov 15, 2010 | 04:04 PM
RA021526's Avatar
ONLY when you're accelerating? NOT when you're coasting, etc?
Old Nov 15, 2010 | 04:42 PM
Rktato05's Avatar
naa just when i accelerate when im coasting its make a noise but no shaking and i do have the check engine on but i havnt got it check ... a friend said it probably my wheel bearing??
Ominous OP's Avatar
Have you checked your motor mounts?
Old Nov 15, 2010 | 04:48 PM
Rktato05's Avatar
what would i look for when i check the mounts??
Old Nov 15, 2010 | 04:50 PM
RA021526's Avatar
Check your codes how to check the codes what they mean. There may be one for a misfire, which would point you in the right direction. Usually with a misfire though (or at least in my case) it was quite noticeable at low speeds/rpms and went away at higher speeds/rpms.
Old Nov 15, 2010 | 04:53 PM
Ominous OP's Avatar
See if the rubber is rotted between the mount and the engine or if the bolts look out of place at all like they stick out. It should all be flush. I don't know how many mounts there are but you should easily be able to check on google how many there are and where they are located.
Old Nov 15, 2010 | 05:03 PM
Rktato05's Avatar
thank you guys alot i will be checking all of this tomorrow
Old Nov 15, 2010 | 05:08 PM
max ride 41's Avatar
rookies helpin rookies, there are 4 mounts. crossmember, passenger side, radiator, ( in front, lower middle ) and a trans mount. drivers side left. and, what makes you think a acceleration problem has to do with a mount? get the codes checked and find out what they are. dont throw money at the car, she'll gobble it up like a ho and be a money ****. trust me, 1 thing at a time, could be a maf problem or a simple throttle body cleaning. check back in when you get code"s.
Old Nov 15, 2010 | 05:11 PM
Ominous OP's Avatar
When I had my caddy, and the mounts were no good, that is exactly what used to happen the car would shake violently only during acceleration. I am not saying that is definatly what it is...just something to check.
Old Nov 15, 2010 | 05:36 PM
Rktato05's Avatar
thanks ....its does shake violently ima check everyone opinions tomorrow
Old Nov 15, 2010 | 06:08 PM
Swazey's Avatar
see whats throwing that check engine lite and im sure you will find what youre looking for
Old Nov 15, 2010 | 06:38 PM
AlexShields25's Avatar
if it's not the motor mounts, it's one of you senors. get them checked out.
Old Nov 15, 2010 | 06:46 PM
lol, whats a senor??? do i even want to know???
Old Nov 15, 2010 | 06:54 PM
Sensor*
eFLO's Avatar
is the shaking/vibration felt through the steering wheel? could also be a bad axle.
Old Nov 15, 2010 | 07:01 PM
z32drifter's Avatar
If you don't find faults in the ecm for missfires you may want to check the inner cv joints. A failing inner cv joint can cause a vibration when acclerating
Old Nov 16, 2010 | 07:18 AM
Ominous OP's Avatar
If it's the cv joints it would make a clicking sound when you turn the wheel wouldn't it? I don't think that's what it is.
Old Nov 16, 2010 | 02:14 PM
gt_35's Avatar
hey i have a problem with my mxima it dont let me go past 2,000rpm anyone know what it chould be??????
Old Nov 16, 2010 | 03:15 PM
luke95gxe's Avatar
maf sensor
Old Nov 16, 2010 | 03:16 PM
luke95gxe's Avatar
to the op check ur passenger side cv axle mine went bad and it shook like hell when i hit the gas
Old Nov 16, 2010 | 03:17 PM
luke95gxe's Avatar
wrong they can go bad without any clicking
Old Nov 16, 2010 | 03:20 PM
pmohr's Avatar
No more Maximas...
Indeed, a bad axle (joint, really) can cause numerous seemingly unrelated noises/feelings, a hell of a vibration on accel being one of them. There may not be any visible sign of an issue with the axle, which can lead to a hard diagnosis.
The clicking generally only occurs when the outer boot has been torn, the grease has all been slung out, and the joint has been severely worn from both metal on metal contact, and road grime/debris being introduced through the broken boot.
Old Nov 16, 2010 | 04:40 PM
beegeezy's Avatar
I would think that there would be vibration when coasting too. Maybe it depends on the severity and stage of axle failure?
Old Nov 16, 2010 | 06:44 PM
luke95gxe's Avatar
no vibration when i coasted only when i was on the gas
Old Nov 16, 2010 | 08:55 PM
AlexxSCM's Avatar
wait wait wait, before any of that... when you accelerate, are YOU shaking the steering wheel violently? :/
Old Nov 16, 2010 | 09:20 PM
my drivers side cv boot has been ripped open and mostly dry for about 2 years. i've driven cars with both boots torn open and never fixed them and they pass inspection as well. not saying you should'nt repair, but unless its making noise, i would'bt worry too much.
Old Nov 17, 2010 | 05:19 AM
Trini Boom's Avatar
Shaking the steering wheel violently?? On purpose?? Is this even possible?? I mean why would he do such thing and then say that he is feeling vibration?
Old Nov 17, 2010 | 06:53 AM
OH EL OH
Old Nov 23, 2010 | 05:34 PM
Rktato05's Avatar
it was a bad pass axle!! ugh
Maxxx10
Sep 13, 2015 03:16 PM
Biatchzxz
58
Oct 28, 2014 03:53 AM
