Exhaust Banging Against Undercarriage
Old Nov 16, 2010 | 10:05 PM
95Maxed's Avatar
Ive had my catback on for a while now, I went with the ebay/custom maxima catback.
This started about a month ago.
When ever I pull a hard turn I hear it bang against something, im not sure what, but it does, and sometimes it hits a couple times before it settles. Ive looked at it and tried to move it by hand but it seems to be in place pretty well. I had it installed by 321VQ35MAX at the dealership he works at, when it was installed I heard no noises, nothing it was perfect. Ideas?
Old Nov 16, 2010 | 10:25 PM
tsheffler's Avatar
-sounds to me like just behind the cat...or where the car would be...right before the 90 degree turn...its bouncing off the cross member support thing....mine does it too when i hit a bump that makes it bounce..
-.it could also be a support rubbing the car around the y pipe area...check that and see if its been scraping...
Old Nov 16, 2010 | 10:35 PM
95Maxed's Avatar
It sounds like its further back, sorta near the axle, trunk area
Old Nov 16, 2010 | 10:38 PM
tsheffler's Avatar
jack up the car on that back side, grab the exhaust where it goes over the axel and see how much play it has...and look around for any dents in the exhaust, or any obvious wear in the surrounding areas where it may be rubbing/hitting.. sorry im not more help:/
Old Nov 16, 2010 | 10:40 PM
I don't have this problema..
Old Nov 16, 2010 | 10:41 PM
tsheffler's Avatar
haha i wont when i put my car on the lift next, and welt the exhaust to the cross member to keep it from bouncing...but i have a new problem to takel first thing in the morning....hence my thread that noones helping me with hahah jkjk
Old Nov 16, 2010 | 10:45 PM
AlexxSCM's Avatar
Mine started hitting when I put on headers and the ypipe so I tied the exhaust to the frame of the car and problem solved mexican status baby
Old Nov 17, 2010 | 01:39 AM
saylee's Avatar
hey, i had that problem too when my rear hanger broke.. you can take it to your local muffler shop and have readjusted and reweld a new hanger that will have your exhaust still and stop it from bouncing up and down..The banging noise gets annoying and i just fixed mine when i put my 2.5 on..
Old Nov 17, 2010 | 07:33 AM
Feldman's Avatar
sounds like your rubber hangers are getting old or may even be broken. might be time to pick up some new ones
Old Nov 17, 2010 | 08:38 AM
ctsnyper's Avatar
Sounds like the axle, under duress, is coming up and smacking your exhaust. Put a bunch of people in the back of the car, and go over some bumps. That should either confirm or deny my theory.
Old Nov 17, 2010 | 08:48 AM
Swazey's Avatar
Check the bracket that is before the bend around the gas tank. its held on with one bolt and comes loose and the bolt can break easily. i had my local exhaust shop weld the bolt to the bracket to make it more of a stud and it took care of my exhaust whacking back and forth.
Old Nov 17, 2010 | 08:52 AM
phatboislim's Avatar
this
mine is hitting as well on the rear axle, i've known i needed some rubber hangers, i just havent ordered any, i may add this to my 200k mi, to do list
Old Nov 17, 2010 | 06:45 PM
95Maxed's Avatar
This has to be it, i managed to grab hold of that bend and shake it and it was hitting something, the rubber hanger felt really weak
Old Nov 18, 2010 | 12:08 PM
cgar's Avatar
My rear muffler braket had rusted and broken off so the exhaust was banging around for a while. By the time I got it into a shop the pipe was cracked right where it enters the resonator. I had them just cut out the resonator and replace with regular pipe and add on a new rear hanger.
Muffler is as quiet as it ever was and no more banging. Paid $90 cash, probably not the greatest deal but way cheaper than a new muffler.
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
seesole
Sep 14, 2015 12:38 PM
