Installing Guage Bezel
Could anyone please help me out with instructions on how to get to the guages on a 4th gen. I have a 95 SE and want to install an aluminum guage bezel. Just need a little help on where all the screws are to get to the guages.
Thanks in advance!
Thanks in advance!
Re: Installing Guage Bezel
Thanks in advance!
Thanks in advance!
First you need to take off the kick panel below the steering wheel. Then take off the casing around the ignition area. Then put the steering wheel at the lowest point and start removing the bezel area. don't forget the 2 screws that point upwards near the intrument panel. Or follow the above post.
Thanks in advance!
Thanks in advance!
Re: Re: Installing Guage Bezel
Originally posted by max808
...don't forget the 2 screws that point upwards near the intrument panel...
i did this simply but carefully, didnt remove any major panels,
1. undo screws in gauge area (up top)
2. remove screws (1 per side) behind the black switches
3. put the steering wheel to the bottom
4. slowly and carefully bend and turn the black piece around the gauges and pull it off, i know u will feel like its gunna break, be extra careful
5. pull out gauge assembly slightly, remove plastic clear clips holding on the cover
6. you have access now, put it on
7. put cover back on and put gauges back into place
8. reinsert black plastic surrounder
9. replace all screws, the ones behind the switches arent exactly easy
10. fix steering wheel
11. enjoy
11. enjoy
Thanks RedMax95 for your detailed writeup.
Originally posted by jiaxima96
What are "black switches"? Power window control switch on left side, and gauge light dim control on right side of steering wheel? I guess so but just want to make sure they are.
pic at
http://maxima.cardomain.com/id/redmax95
ya, those are the ones, i popped them out, and i think the screw was behind the one closest to the steering wheel on each side...[/url]
Thanks again. BTW your car looks much shinnier than mine.
Violator
09-09-2015 10:14 AM
