Engine Tapping
Old Jun 19, 2012 | 07:33 AM
  #41
max1008's Avatar
Originally Posted by BenL
I switched my engine to full synthetic at 140,000 miles (currently at 146k, was given to me at 136k) after it had been run on conventional for its entire life before that (my mother was the original owner up to that point). This is also taking into account that she had run it almost completely out of oil once in the car's life (luckily I had caught that mistake before it led to a major problem). As soon as I got the major work that needed doing to the car (full exhaust, suspension, etc) I switched it over to full synthetic... on my second oil change since switching and it just keeps running (and sounding) better and better the more the sludge keeps getting worked out. The extra power is nice also.
I would change your oil with crap oil and good filter, pour seafoam in it, crank the car let it idle for 15 minutes or so then drive it down the road (15 minute ride, don't beat her up on your drive) and then come back pull the plug and watch the nasties come out of her. Let it drain for about an hour. Then put the good stuff back in with a new filter and see how she feels then...I felt a difference with mine.
Old Jun 19, 2012 | 07:34 AM
  #42
max1008's Avatar
Wow sorry guys feel like a NOOB, don't even know how I found this thread. Wasn't paying attention to the dates..
Old Jun 19, 2012 | 12:03 PM
  #43
maxinout93's Avatar
[QUOTE=asand1;8030395]Not sure on that one. Does the knock come with the light every time? Is it an even knock, or or is it funky rythm (same two or three cylinders)? Does it sound like its deep in the crank case, or in the heads?
Two possibilities that come to mind are oil pressure reliefe valve, or main bearing
sometimes spinning and
blocking off oil galley to crank.[/
QUOTE]
I had a 91 chevy beretta v6 that had a similar issue. I started it up one day n all i got was a tapping noise like it wasnt gettng enough oil or the oil pump had blockage. Drove it around to try and build up the pressure. And the tapping stopped, then it came back, and it would do it bak and fourth. Mechanic said the oil pump was dying. Putting some heavyweight oil in the engine helped a little to buy some time. But eventually i ended up blowing the engine from oil starvation(oil pump died.
Socalstillen
Sep 20, 2015 11:46 PM
dcam0326
Sep 18, 2015 04:52 PM
tardrex
Sep 11, 2015 07:35 PM
ballerchris510
Sep 11, 2015 05:29 PM
popdedop
Sep 11, 2015 11:17 AM
