wut did i do wrong?
Old Dec 18, 2001 | 08:15 PM
NyC97Max's Avatar
wut did i do wrong?
i kno u people are probably gonna tell me search..but i did..and i tried to go about doing this. My headlight socket burned out, so i decided to switch it on my own...the mechanic was charging me 60 when all i had to do was buy a $3 thing and rewire it..well i did just that...i disconnected the battery...snipped the wires from the old socket, connected and soldered them onto a new socket...plugged the new socket in...connected the battery back up...and the headlight still dindt work...did i do sumthin wrong? did i blow a fuse? how can i check the fuse? wut do u suppose else can be wrong?? thanks
Old Dec 18, 2001 | 08:22 PM
gaios1's Avatar
Check the fuse for sure. If the socket failed then there is a good chance that something shorted out and blew a fuse. Look in the fuse panel (just above the hood release inside the car driver's side), find the headlight fuse, and see if the internal filament has broken.
Later,
Peter
Old Dec 18, 2001 | 09:19 PM
Asian_N02's Avatar
did you check your wiring? there are three wires, one for high beam, one for low beam, and one for ground. you need to make sure you wire it correctly. I just rewired mine for an H4 bulb and they look sweet!
Old Dec 18, 2001 | 09:30 PM
MONTARABOB's Avatar
Re: wut did i do wrong?
Also, there are 2 fuses, one for each side.
BippuBenji's Avatar
Yea, first make sure your fuse isn't blown and then go back and make sure all the wires are correct, I remember myself going back because I wired grounds to lows and vice versa. It sucks because my factory wires are green, yellow and black and confused me when I lost track of which was which.
Old Dec 18, 2001 | 11:02 PM
Zack_Rad's Avatar
headlight
is the bulb blown?? I'm guessing that you probably replaced it. I just didn't see that mentioned.
-Zack
Old Dec 19, 2001 | 12:22 AM
BlkStnValyMaxima's Avatar
Later,
Peter
That is not where the headlight fuses are located in a 4th gen. They are in the engine bay, in a little relay box located near your battery.
Old Dec 20, 2001 | 12:04 AM
NyC97Max's Avatar
well thanx for the help..i did wire it correctly..no fuses were blown..but as u said, dat i PROBABLY did, i didnt do...which was replace the bulb,,,because when i first looked at the bulb it didnt seem burnt or damaged in anyway..but a TINY lil part of the filament was cracked off..so dat was the prob...i also realized im running on 80/100 bulbs which imma reduce to the 45/65 hyper whites...ill lose my nice hot blue bulbs that i have now, but i dunno if theyre worth it...thanx...maybe ill upgrade my socket sumtime
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
220k+ A32
Sep 11, 2015 02:18 AM
