Will it fit? 15x10 25 mm offset (front)
Old Dec 13, 2010 | 03:07 PM
aic96max's Avatar
looking into some wheels for a slick setup, looking at some weld pro stars size
15x10 w 25mm offset
anyone have any idea if this will fit.. personally i dont care it they pop put an inch or so , more interested in knowing it will clear the brakes and stuff on the inside
any input appreciated
Old Dec 13, 2010 | 04:36 PM
Do you have a BBK? If not I think it'll clear but I'm not 100% sure.
Old Dec 14, 2010 | 12:28 PM
cardana24's Avatar
Blown
What size tires are you going to run?
IMO that is not a low enough offset for that width. Yes they will stick out from under the fenders, but I also think at that width and offset you will hit the struts. Why do you want something that wide you going to run 305's?
my 16x8.5"s +35 with 255/50/16s stick out a little past the fenders and are really close to the struts.
as for brakes, if you brakes are stock I do not think that will be a problem since some fourth gens came with 15" steelies and I think their offset was +40.
Old Dec 14, 2010 | 12:33 PM
aic96max's Avatar
well im looking for some slicks, and i found on ebay a set already with these rims which seemed like a good deal. tire are 26x10x15 et street but im thinking it may not work.
thanks for the input
Old Dec 14, 2010 | 12:56 PM
Nealoc187's Avatar
SLOW
i don't think they will work. 25mm offset on a 10" wheel is basically a 6" backspacing. I'm almost positive that will be hitting your strut. also you will definitely have to run spacers because of the spoke design.
you don't want those wheels anyway in my opinion. even if they do fit they will a) look retarded, b) require spacers and c) drive you insane. pro stars use shank style lug nuts which are just a pain in the ***. i have used them, my friend has some that I've borrowed a few times. it takes like 6 times longer to install and uninstall them than a "normal" style lugnut. it would be more bearable with a cordless impact wrench, but still annoying.
Old Dec 14, 2010 | 01:15 PM
ajcool2's Avatar
Might look something like this.
Old Dec 14, 2010 | 03:52 PM
dame_dashvq30's Avatar
and that is a goooddd look....
Old Dec 14, 2010 | 05:43 PM
aic96max's Avatar
Aj, do you remember the specs on those wheels? bc its the same wheel, but id like to know the offset
Old Dec 15, 2010 | 10:07 AM
ajcool2's Avatar
I'll check them when I get home. I might be selling them soon also. Getting a set of slicks.
HOKUSMAX
Nov 13, 2017 04:34 AM
Devo
18
Mar 7, 2016 07:36 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
delerium75
Aug 19, 2015 11:08 AM
twotonezed
Aug 16, 2015 11:41 AM
