ECU switch
Old Dec 19, 2001 | 08:34 AM
Eric99SE's Avatar
ECU switch
Here's the deal. The adjustment/reset switch on my ECU broke off the other day. I now have no way to check codes or reset the ECU. I have taken it out, and looked into trying to repair it. However, the way it broke, you can't get any sort of decent solder connection. I am considering running some longer leads from the circuit board to a new switch. Problem is, I don't really know what the specs of that switch would be.
There are three wires that go into the switch. Even though the switch is a rotary one, there are really only two positions - run and diagnostic mode. Could I get away with just putting a two position switch in there?
I really don't want to shell out the money for a new ECU (not until I really screw this one up!!).
Thanks for any ideas...
Old Dec 19, 2001 | 09:08 AM
Sprint's Avatar
not sure what to tell you Eric.. but i do know that ECU's will cost $100 - $200 from a junk yard..
Old Dec 19, 2001 | 11:46 AM
Eric99SE's Avatar
Problem solved!!
Well, being the impatient one that I am, I went for it. Some 24 Guage Bus wire, shrinkwrap, and a two way toggle switch, and I am back in business.
Went in easy, and it worked. Now checking engine codes is as easy as flipping a switch.
I figure if my $6 dollar fix doesn't last forever, at least I had some fun with it!!
Old Dec 19, 2001 | 11:52 AM
Sprint's Avatar
hmm.. interested in doing a write up?
i think my screw is screwed.. i think i turned it too many times.. now it just keeps turning
Old Dec 19, 2001 | 11:57 AM
Eric99SE's Avatar
I may do a write up, but first I am going to drive it around for a while to make sure it continues to work.
I found that the screw was always pretty touchy, and from the looks of it, pretty easy to strip. I had only used mine a couple of times before it broke off, and it is pretty messed up.
I will try and get some pictures posted at some point as well.
Old Dec 19, 2001 | 12:34 PM
ejj's Avatar
ejj
This could be really useful for those of us who trip the CEL often...where did you wire this switch to? Is there a connector exposed on the ECU that you can use, or did you have to take the RESET screw out?
Old Dec 19, 2001 | 12:40 PM
Eric99SE's Avatar
When the reset screw switch broke off, what remained was a plastic spacer that supports the three wires that go down to the circuit board. (A picture would really help here...)
Anyway, I wedged a piece of 24 guage bus wire down next to each lead, soldered and shrink wrapped it. Then ran the three wires out the hole where you normally put the screwdriver in to adjust it. I then ran the wires to a small toggle switch, making sure that the middle wire from the board (ground I assume) went to the ground of the switch. I then just mounted the switch on the outside of the ECU. That way I just half to pull off the kick plate and flip the switch.
So far so good...
Old Dec 19, 2001 | 12:44 PM
ejj's Avatar
ejj
So far so good...
Wonderful idea. Can you take the RESET screw out without breaking it?
Old Dec 19, 2001 | 12:56 PM
Eric99SE's Avatar
I'm sure anything's possible...
Seriously though, I have no idea. Since mine broke pretty easily, I imagine you could do it. Just open it up and have a look..
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
